![]() ![]() Join Date: Feb 2004
GM 502/502 Quiet Lifter recommendation
I have a 502/502 (1999) that will be in my 1966 C10 (4L80 trans). It has the stock GM cam but I need to purchase a set of lifters that are quiet if possible. This truck will not be a racer but will be a cruiser. thanks
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt Last edited by dennislbrooks; 03-19-2026 at 08:36 AM. Reason: words |
Re: GM 502/502 Quiet Lifter recommendation
Is it a solid lifter cam, is it adjusted correctly ? Valve lash.
Is it a hydraulic cam, is it adjusted correctly ? Preload. |
If it was me, I'd use stock liffers with a stock cam.
Here is the full story.
The engine actually is not mine but a friend putting the 502 in his restorod. The 502 is a 1999 model never used because of mouse damage then sold off. The engine was still in the crate with no intake/carb mounted yet. He replaced one head with a like 502 head and replaced the cam (GM) and 5 lifters (GM) that appeared/had corrosion from mouse urine. The valve lash has been set correctly by 3 or 4 people and it is still noisy as hell. I suspect lifter damage on other original hydraulic lifters from mouse urine. I am trying to convince him to replace all the lifters. Is using the GM 17120060 HL121 instead of the GM 17120061 HL122 lifter, OK? He runs the paperwork recommended oil 10W30. Or how about Melling or Sealed Power? thanks
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt Last edited by dennislbrooks; 03-20-2026 at 07:34 AM. Reason: words |
There are internal valving differences.
The 061 flows more oil to the rockers. |
| Bookmarks |
