Old 11-13-2004, 10:34 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
For sale- lowered, big block, shortbed truck
It's time to sell the famous Tx Firefighter Cool As Hell (TM) truck.
I'll supply proof of over 7 thousand dollars spent in parts alone in the last 18 months. I'm asking 6 thousand dollars for the truck.
I'm the third owner of this thing. It's an original Texas truck with worn out original paint on everything but the front fenders. It's a solid truck, it doesn't need rockers or cab corners or any of that stuff.
I bought this truck as an untouched original 6 cylinder 3 speed no option truck.
Everything listed below, I've done, and all has less than 5k miles since I did it.
It's got a 35k mile since new 454 engine, a fully bulletproof turbo 400, new 1 piece driveshaft.
Converted to 5 lug front and 3.08 rear.
Lowered 4.5 and 6 using all the good stuff from ECE, super track bar, short KYB shocks.....
All new brakes, booster, master cylinder, hoses, bearings, calipers, pads, shoes, wheel cylinders....
Engine has been resealed with all new gaskets, seals, timing chain, new water pump, fuel pump, belts, hoses, 4 core radiator.....Edelbrock intake, Edelbrock 750 carb, new HEI.....
It's all detailed with POR 15 paint, lots of bead blasting, all correct and original pulleys, brackets, mounts, fan shroud...it's all done right. You can buy any part for an original big block truck at the parts store and it will fit like it should.
Inside has a tilt column, new dash pad, original uncut dash, radio block off plate, late model truck steering wheel.
Has 15x8 Cragars all around with BFG tires.
Converted to power steering, power brakes, and big swaybar. The swaybar is the FAQ article that I did, you can see picture of it over there.
I converted the front clip to 72 style with a billet grille insert and new chrome bumper.
This truck drives straight, doesn't leak, rub, bump, or grind. My wife can drive this truck without any trouble. I was a mechanic professionally for 12 years, so I do stuff right. I'm also an obsessive freak, so stuff has to be neat too.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-13-2004, 10:49 PM   #2
Tx Firefighter
Old 11-13-2004, 10:58 PM   #3
Tx Firefighter
New GM cab mounts too. New NOS GM exhaust manifolds, dual exhaust with Dynomax Super Turbo mufflers, new battery cables, Lokar kickdown kit for transmission.
Since these pictures, I did the new dash pad, tilt column, new steering wheel, and converted dash to guages from idiot lights, and put original block off plate in dash.
Old 11-13-2004, 11:15 PM   #4
71k20
PM on the way.....
jerrykay@austin.rr.com
71k20 is offline   Reply With Quote
Old 11-14-2004, 08:10 AM   #5
Tx Firefighter
All PM's answered
Old 11-14-2004, 08:12 AM   #6
GMC AMI
GMC AMI's Avatar
Real nice truck, good luck on your sale!
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 11-14-2004, 01:00 PM   #7
Tx Firefighter
I'd swap it for a nice 67-72 dually or even an early 73-87 style of dually.....
Old 11-14-2004, 08:22 PM   #8
Tx Firefighter
Someone step up or I'm going to part it out next week.....seriously.
Old 11-14-2004, 08:36 PM   #9
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
part out a 6000 dollar truck ?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 11-14-2004, 08:39 PM   #10
phlegm
Still Green but learning
phlegm's Avatar
Always so far away!!!
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 11-14-2004, 08:54 PM   #11
browndawg71
your probably not interested but i got a 95 dodge 1 ton 4x4 w/ the ctd in it ill trade you.
every man must believe in something, i believe ill have another beer!
browndawg71 is offline   Reply With Quote
Old 11-14-2004, 08:59 PM   #12
browndawg71
nice truck , please dont part that out. it would make someone a good truck.good luck.
Old 11-14-2004, 09:11 PM   #13
CG
BlahBlahBlah
wow i hate to see you part that but if it comes down to it...i would be interested in your complete drop kit if it would work on my 72 burb.
Old 11-14-2004, 09:38 PM   #14
Trey`
Active Member
Trey`'s Avatar
Don't part it out , Let me see if I can get my truck sold and see what we can come up with.
Trey` is offline   Reply With Quote
Old 11-14-2004, 09:54 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have the perfect truck for you to part out....if you really want to part something out, let me know and I'll trade you trucks.
TTT for ya tex.
Old 11-14-2004, 10:23 PM   #16
chevy72402
FARMER/RANCHER
chevy72402's Avatar
I think I can get you a 67 or 68 short wheelbase dually. With a 327 in it. it was running propane but hasn't ran in a while. I think the head cracked. it has no bed on it. and is a one ton.. let me know.
1972 chevy super, long box, 402 big block (2,000 miles on rebuild) 2wd tach, tilt, tool box on bedside, a/c, sliding rear window, orange and white.
1972 Chevy Blazer 2wd, tach, tilt, a/c, my first engine overhauling experience, Orange, with white top
2006 Gmc Sierra, XM, Z-71, dark blue, onstar, leather, rear entertainment (audio only) heated seats, (the wife loves that feature) upgraded tires immediately after purchase to Goodyear Wrangler AT/S (hate those rock throwers that come from the factory)
BWC
chevy72402 is offline   Reply With Quote
Old 11-14-2004, 10:30 PM   #17
Longhorn Man
a SWB one ton dually???
Old 11-14-2004, 10:38 PM   #18
Tx Firefighter
I think he means a 133 inch dually rather than a 157 inch truck.
Old 11-14-2004, 10:40 PM   #19
Longhorn Man
duh...I shoulda known that.
Where is the smiley face with crossed eyes saying DUH?
Old 11-15-2004, 12:29 AM   #20
chevy72402
FARMER/RANCHER
chevy72402's Avatar
lol, Is that something that you are interested in? I would have to get ppics this next weekend. Let me know..
BWC
Old 11-15-2004, 02:51 AM   #21
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Hate to see all your work parted out, but if you really do I would be interested in your nice grille conversion and cragars.
-Ron-
OldSkool71 is offline   Reply With Quote
Old 11-15-2004, 02:53 AM   #22
67ChevyC10Stepside
if u end up parting it can i get the auto linkage?
Old 11-15-2004, 02:59 AM   #23
71Longbed
Not Mine But A beauty
71Longbed's Avatar
i would not part that out no matter wut
68 Chevy Shortbed 454/400
2000 Chevrolet Camaro SS 6spd
2011 Silverado 5.3 6spd auto
71Longbed is offline   Reply With Quote
Old 11-15-2004, 08:00 AM   #24
Tx Firefighter
Chevy72402, I already have a 72 dually, I just need one on the road right now. My dually needs work to be ready and I have business waiting on me. I need a runner right now so I can work ASAP. I don't think I'd want another non runner right now.
Everyone else, it's just a truck. There's thousands of them all over the place. It wounldn't be sacrilege to part it out. That 454 is worth some coin and so is the lowered chassis stuff. I think I can make it worth as much as parts as it is assembled. All of the stuff underneath the truck has been detailed and rebuilt, so I won't have any trouble selling it off on the parts board.
Old 11-15-2004, 05:59 PM   #25
Tx Firefighter
Fellows, there seems to be some confusion here amongst some guys. I do not have time to wait around for this thing to sell.
I'm dead serious when I said I'll part the truck out. If it's not sold and gone by the weekend, I'm pulling it apart on Saturday. No joke.
I'm still waiting on some emailed pictures on possible trade deals for running duallys, otherwise, it's going to be a busy Saturday.
See, I have a welding/ fabrication business and I need another work truck, like bad. My 72 dually has no drivetrain in it now, so if this truck doesn't sell by Saturday, the 454 and transmission and all of the stuff that goes with it is getting stripped out of the short bed and put into the dually so I can use it to work starting Monday.
