hahaha
Were to get B.B. mounts quick, I knew the 6 was gonna go but now?
My life is life is like this, I always need something at the worst time. I was getting parts together to put the 454 in but wanted to do it in aug. but now have a bad rod knocking on heavens door. My model A is getting fixed from being rear ended from the last time the truck was down and I was using it as a parts runner. So I need something to drive in a hurry, and I have the block ready this seems to be the best way out. I know this has been answered before but I forgot the answer. I need motor bracket, mount, and frame towers any thing else?? And where can I get them fast, they need not be the best deal as I need them now. Thanks, in advance for your help, Joker69
69lwb, 29 A coupe hotrod, 55 chevy hardtop, |
Thats the Hillbilly way
Thy Desert Rat he probably has some..
Bill ![]()
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Micah (sp?) is the guy to talk to about those,TTT so you can get these quick
Truckin' Krazy
![]() Join Date: May 2000
I've got a set out of a 70 that had a 402, I also have a set of B.B. exhaust manifolds, they could be shipped on tues. 100$ for the mount's & towers. Thanks Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
hahaha
Tom, Is this all I need in the way of mounts? I wan't to get it all the way in at the same time.
![]() Join Date: Dec 1999
If he cant help you out i have everything to convert truck to a big block.Can go either way Long or Short Pump,Long Pump is way cheaper,i have both styles and plenty of it,and the 67-71 towers,and a set of 72 towers. gmcrat427@yahoo.com my name is Micah
![]() This is the correct parts for 69-71 only difference in 68 is upper alt bracket,and in 72 it changed also.i have all available.but ill have to check on shrowds my dad needs one,so i might only have a few left. Last edited by Desert Rat; 07-01-2002 at 12:30 PM. |
hahaha
Desert Rat, Thanks for the post. I don't need all the brackets for the motor itself, but I do need the mounts that attatch to the block. I don't see these in the photo, do you have them? Also I have read somewhere on here that there is a break in the years and the rubber mounts for one are cheaper than the other years, but that they will both work well. Any differences or ideas about this? Thanks, Joker69
Project Junkie! Fishing Poor!!
What transmission are you going to use? If you are going to use a standard you will need the crossmember that goes under the bell housing. The BB crossmember is located in a different possition so it is shaped different. I don't have one, but I have had in the past. If you are installing an automatic you will be allright as far as the transmission goes, but you will need the frame bracket for the auto transmission (as they are different) and I may have one of those. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
i have used rubber mounts but id recommend new ones they are quite expensive they were well over $100,if on budget use truck sb motor rubber pads,and a big basher under mount.or goto 72 style.i have those. someone on here wanted said they were sending$$$ but its been a while.the tranny linkage frame bracket is different but you can certainly use sb one.if Wes dont have any,i have quite a few.
hahaha
Desert Rat, The question is more about the "clamshell" that bolts to the block. I don't see these in the photo. The second part was about the cost of the rubber mounts. Thanks for the further info, Joker69.
rubber mounts go with this style in pic,clamshells are for 72 different tower all together.
