what happened to flint mi
how tuff is it to install a tach dash into a non tach truck
my blazer has a full dash and no tach how difficult is it to install? tools need ed ? thanks for the input
71 swb 2wd fleet frame off in progress 72 4x4 blazer daily driver 70 olds cutlass s mint condition owned by a grandma 56 gmc 2wd project waitng 97 fiance mobile |
Re: how tuff is it to install a tach dash into a non tach truck
Sorry, I don't have an answer, but I'd love to hear from one of the members who have done this successfully.
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
saving one more
Are you wanting to use an original tach dash, or add a tach to your existing dash?
I put an Autometer tach in the center hole of my existing non tach dash, had to make a spacer due to the printed circuit board on the back of the dash panel, do some cutting and grinding, wasn't too hard to do.
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab |
![]() Join Date: Mar 2006
This guys have a conversion kit for putting a orginal tach in your dash!
http://www.truckandcarshop.com/trucks60_72/t60_032.html |
![]() Join Date: Mar 2003
If going factory style, you need a phillips screwdriver and a 5/16 wrench and the correct harness to hook up to the coil.
![]() Join Date: Feb 2004
This is the easiest swap out there going, just unbolt a few screws, unscrew you oil pressure line, and speedo from the back of the speedometer and out comes the console, then just a few screws, to unbolt the bezel and backing plate, switch out backing plates, install the tach, finish with replacing the bolts and there you have it,
that easy
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
67-72 Addict!
Here is mine with an aftermarket tach and clock. I'm finishing up another one with a Camaro tach and clock soon. Check the FAQ forum for directions that others have posted.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 04-03-2006 at 07:38 AM. |
i have a tach dash i just need to know about the wiring is there a harness i need to buy ? im guessing there is , and i did a hei swap will the factory tach work?
#9 | |||
Union Electrician
Yes the fact tach will work with HEI, and the fact wiring harness will work as well. Just need to cut off the fork lug and replace it with a insulated female spade lug and hook it up to the spot marked tach on the HEI dizzy and your in business. Randy
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
#10 | |
Semi-Senior Member
GMC Paul's web-site has a tech tip, part-way down the page on how to do it. http://www.gmcpauls.com/Tech%20Tips1.htm Numberone son bought a used dash unit that we had to go thru, combining parts/gauges from 3 different dash units to get to it to work. I think someone just plugged the dash to the unchanged wiring....hoping it would work.....and let the 'smoke' out of the gauges.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab Last edited by 68speedalert; 04-04-2006 at 01:32 PM. |
Jim, those white face gauges look awesome. I usually don't like that because they are usually aftermarket gauges and I like the style of OEM, but that is a clever way to modernize and keep the classic look! I'm gonna think about that when I get to painting my bezel since my interior is black with grey accents. How did you get the gauges mirror imaged like that though? Purchased?
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
#12 | |
The LuvShack Garage
