Old 06-26-2006, 06:26 PM   #1
cobinder
Everything is work in progress
cobinder's Avatar
Talking front & rear hubs?
Anyone ever narrow their corp 14 bolt, by bolting on the type "B" hubs from a chassis cab truck? Know of where a guy could find a pair? and change to rear disc's
I'm looking to change my 80 3/4 ton Dana 44 front hubs to the larger spicer 44 hubs from the mid 70's models, anyone ever do this? know where I could find the parts with disc brakes?
thanks for any help
80 GMC 3/4 ton 4x4 chassis under a 49 International 1 ton
cobinder is offline   Reply With Quote
Old 06-27-2006, 11:32 PM   #2
Americanrider
Re: front & rear hubs?
C&C dually axle are scooped out of the junkyards fast, faster when you are in an area that has a high 4x4 population. Up here expect to pay 350-650 for one IF your lucky to find it. They are favored for their strength and compact size. Swapping in disks should not be to much of a hassle. Check out Blackbird's Custom trucks, they can point you in the right direction.
What are you looking to gain by getting the bigger hubs? You could change the outter knuckles with an older (71-74) D44 axle and get bigger bearings along with the bigger hubs, is that what your after?
Americanrider is offline   Reply With Quote
Old 06-29-2006, 04:56 PM   #3
drink2mny
drink2mny's Avatar
PM sent
Support The Board
drink2mny is offline   Reply With Quote
Old 06-29-2006, 06:34 PM   #4
1969 GMC
1969 GMC's Avatar
you can also find those hubs on 88+ drw pickups (as well as C&C trucks), basically anything with dual wheels.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 07-03-2006, 10:22 PM   #5
cobinder
cobinder's Avatar
Yeah I only want the rear hubs to narrow the rear end. I don't need anything else from the rear axle. I could used a wasted housing and be fine. I hate to pay $350 plus for just the hubs.
On the front I did want the bigger bearings and bigger hubs. Bearings for oversize tires and hubs for looks.
I'm hopeing to find a couple of broken axles and just buy the hub hardware.
Having a hard time located just those parts, my housings are fine.
Thanks for any and all input
