Old 07-17-2006, 11:05 PM   #1
tom71
what happened to flint mi
tom71's Avatar
sm465to muncie 4 speed swap questions
has anyone done this swap ?? do you think you could use the old linkages and stuff to make it work ? any input would be great thanks tom
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 07-19-2006, 09:12 AM   #2
Jason915
Re: sm465to muncie 4 speed swap questions
Are you thinking of going from TH350 to M465? Or 3speed man to M465? Either way it's a stright forward swap. These trucks have everything from the factory to go either way like the hole for the clutch rod in the floor and the other clutch linkage mounting points. You will just need a hanging clutch pedal all of the clutch linkage, the right steering coulmn, the right trans to t-case coupler, and of course the transmission. Ideally what would be the easiest is to find a truck in the J/Y that has everything you need and just take it all so you can visually see what the differences are.
Good luck
P.S. PM me if you need a hanging brake and clutch pedal assembly
1971 GMC K1500 SWB Fleetside, 4" skyjacker softride and, 14 Bolt FF, HD Dana 44 4.10's
1970 K5 TBI conversion lifted etc SOLD
1968 C20 camper truck SOLD
“To ban guns because criminals use them is to tell the innocent and law-abiding that their rights and liberties depend not on their own conduct, but on the conduct of the guilty and the lawless.” Jeff Snyder
Jason915 is offline   Reply With Quote
Old 07-19-2006, 09:28 AM   #3
Need more info:
*What do you have now?
*What transfer case do you have?
*What did the SM465 come out of?
Old 07-19-2006, 01:56 PM   #4
tpi72blazer
Tpi72Blazer
tpi72blazer's Avatar
Are you planning on putting the Muncie 4 speed in a 2 wheel drive? If that's the case it should be an easy swap - you would have to change the crossmember and drive shaft more than likely. If you want to put a Muncie into a 4 wheel drive application it won't work as you will not - to the best of my knowledge - be able to adapt it to mount to a transfer case.
Indian - the other money pit
tpi72blazer is offline   Reply With Quote
Old 07-19-2006, 11:09 PM   #5
tom71
tom71's Avatar
more info : i have a blazer that i was thinking about converting to 2wd it is already a stick shift i believe it has a sm465 and i d like to put in a muncie when it is all done and said . but i also have a 71 2wd that has a th400 in it , i thought about putting a muncie in that as well , nothing like jammin thru the gears . thanks for the input guys ....tom
97 fiance mobile
Old 07-20-2006, 08:22 AM   #6
I like the 4-on-the-floor,too.Let me put the swap this way:If you had a three-on-the-tree a Muncie M20,21,02,or 22,also the Saginaw SuperT10 will bolt in.The M22 has fine-splines and needs a yoke and clutch assembly to match.
So,if you got one of these car-type trannies and all the necessary stuff from a 3-speeder,it is stone-simple.
