Old 09-03-2006, 02:01 PM   #1
chevyboy55
chevyboy55's Avatar
Fuel line hit's air cleaner
We put a stainless braided line from the pump to the carb.(edelbrock) & when I put the air cleaner on, the base hits the fuel line & you have to force the air cleaner down to get it on. Has anyone run into this? It is the Spectre line with the Magna clamp ends not the true an fittings.We did not have this problem with the rubber hose.Could the braided hose be THAT much thicker?
Also, it is hitting about about 1 1/2" out from the carb.
chevyboy55 is offline   Reply With Quote
Old 09-03-2006, 02:07 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fuel line hit's air cleaner
Your rubber line was probably hitting it and you never realizrd it.. at least that's my experiance.
You can buy a new plastic air filter spacer at most of the parts stores, or in the junk yard on any chevy van from the 70's or 80's, the taller the spacer, the more likely you'll need a new stud though...esp if you go the van route.
Old 09-03-2006, 02:24 PM   #3
ChevyDude
Here's how I did mine, goes to the back of the carb and makes a 180 degree turn up and back towards the carb. I know you guys hate the glass fuel filter houses, lol...I also have a Summit ceramic filter at the carb and a fuel pressure gauge.
ChevyDude is offline   Reply With Quote
Old 09-03-2006, 02:48 PM   #4
QKENUF4U
QKENUF4U's Avatar
i had to buy a fuel line from checkers that goes straight down from the stock location and under where the choke would sit (chrome 90* line). they do make an air filter base thats built to go around the eldelbrock fuel fitting but i already had a good air cleaner so i didnt want to buy another.
QKENUF4U is offline   Reply With Quote
Old 09-03-2006, 02:56 PM   #5
cdowns
cdowns's Avatar
summit, speedway, edelbrock,hollet,jegs.pepnoys napa advanced auto auto noze all offer fittings that you can reroute your fuel line with to clear your air filter// the trick is you just have to outthink it
Old 09-03-2006, 03:30 PM   #6
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Not sure about your fit problems witout pics, but...
It sure looks like Edelbrock's line & filter (no da**ed glass & clamps) kit is hard to beat. You just add AN/braided line to the fuel pump.
There are also some nice alum carb-to-air cleaner spacer to give you a little more clearance.
PICKMUP is offline   Reply With Quote
Old 09-03-2006, 05:55 PM   #7
Longhorn Man
I see 2 problems with that... if it is chrome, then I'll bet it is chrome on the inside too. It's a PITA when the chrome flakes get in the carb. I've had it happen a few times.
Also, there is no reason in the world to run the fuel so close to the engine (heat source). It's just askin for trouble. (vapor lock trouble... not fire trouble)
Old 09-03-2006, 07:35 PM   #8
chevyboy55
chevyboy55's Avatar
It seems to be hitting right where the box is. I think a spacer should do the trick.
I posted the pic & the box did not show up. It's about where it starts to bend.
Old 09-03-2006, 08:57 PM   #9
Roachgod
Roachgod's Avatar
I have an edelbrock 750 with electric choke and an edelbrock elite air cleaner sitten on a performer2 intake on a bbc and here's what my local speed shop sold me.
6AN carter afb adapter part# aqp fcm2112 for 5.95
6AN 90degree hose e part# aqp fcm4032 for 15.95
I got this a Martel Bros. Racing in katy tx and they aren't usually the cheapest but they always steer me in the right direction and I can ride my bike there.
1970 custom/10 (was 8-350)
long bed
factory a/c,power steering, power brakes
added front disc brakes from a 72 and rear axles 5 lug
79 chev 1 ton
01 GMC Jimmy
Roachgod is offline   Reply With Quote
Old 09-04-2006, 12:31 AM   #10
QKENUF4U
QKENUF4U's Avatar
mine is setup like PICKMUP but roach's idea is better for you since you running braided lines already.
Old 09-04-2006, 12:55 AM   #11
hotrodhomi
hotrodhomi's Avatar
I have one of these edelbrocks on my truck. I like it, but when I needed one for my blazer I got the 15 dollar one from summit instead of spending another 50 plus dollars on the edelbrock.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 09-04-2006, 03:03 AM   #12
junkyardjohn
junkyardjohn's Avatar
What You Need Is Called A "banjo" Fitting. Edelbrock Makes Em, & I'm Sure Other People Do Too. It's A Hose Fitting That Replaces The Straight One Going Into Your Carb With One That Is 90 Deg. & Swivels Until You Tighten It Down. I Think I Have One Around Here. I'll Try To Find One & Post A Picture. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
