Old 12-13-2006, 12:09 PM   #26
st1x10
st1x10's Avatar
Re: 67-72 bagged exhaust
I was looking for some mid length from hedmann or hooker anybody got a part number or a link. Thanks. Right now I have some full lengths that are rusted and below the frame right now.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 12-13-2006, 09:56 PM   #27
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by bodydropped68 View Post
here's one pic i have of my exhaust were it exits,i'm running block huggers and it runs on the outside of the frame then between the frame and rear tyre's following the frame kickup over the axle.
Originally Posted by XXL
I routed my head pipe to the outside of the frame rail just as quickly as possible behind the front wheel (where the frame comes up at an angle to the front xmember). Once outside the frame, it's pretty much a straight shot all the way back to in front of the rear wheels. The rocker hides everything (my muffler is under the cab, behind the rocker because there's not much place after the cab for a muffler on a stock frame stepside.
Either of you run into clearance problems with the front tires when turning? Looking at it, it seems like this would be a problem. -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-13-2006, 10:09 PM   #28
jkade
jkade's Avatar
I have the flowtechs headders for a 72 402 truck reckon they will work? I am not changing the front cross member or any of that. I am going to do the air ride for more of the ride quality than laying the frame so I was wondering if I could use the flowtechs.
jkade is offline   Reply With Quote
Old 12-13-2006, 10:59 PM   #29
XXL
Señor Member
XXL's Avatar
None whatsoever. 27" tire on an 8" wheel.
XXL is offline   Reply With Quote
Old 12-14-2006, 10:08 AM   #30
XXL
Señor Member
XXL's Avatar
For Rollie396...
Old 12-14-2006, 07:59 PM   #31
Rollie396
someday it will be done!
Rollie396's Avatar
Thanks XXL,that's one of the spots I was wondering about.
I just never get tired of lookin at that cab!
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 12-20-2006, 11:27 AM   #32
jlaird
jlaird's Avatar
I thought of this pic when I read this post. I think those are exhaust pipes anyway...
jlaird is offline   Reply With Quote
Old 12-21-2006, 10:44 PM   #33
Rokcrln
Rokcrln's Avatar
I am running the 3/4 length Sanderson headers with 3" colectors. Right now it is mocked up with 2 1/2" from the colector since I had it all laying around. But the final system will be all 3" aluminized mandrel bends (summit) that run under my tubular trany cross member that is made for my exhaust then under my trailing arm cross member that is also notched for the 3" tubes. Then right after the cab ut turns up and over the arms and ties into the flowmasters that are up by the bed floor (my floor is raised up 6") then will go under the shock cross member (center lifted for this to happen) and will roll down over the rear diff between the axel and te rear tank. It will be tight but 3" will make it all the way out the back and exit right between the tank and teh rear quarter panel at an angle. I may need to make my tips since their is not 3" of space between the ground and body so I may take some 3 or 4" and oval it out to fit for my tips.
These pics do not show alot but it may give you an idea. The new system should be in and tiged in the next month ir two in my spare time.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
