Old 12-01-2006, 11:22 AM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
67-72 bagged exhaust
Looking at this, it seems that there will not be much room to route pipes. What are you guys doing? Ideas? Pics?
Thanks -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-01-2006, 12:51 PM   #2
jimmydean
jimmydean's Avatar
Re: 67-72 bagged exhaust
Not sure what you're looking at, but I plan to go with a mid-length header and custom tubes and dump my exhaust just after the trans (sort of muscle car style). Just a 45 degree end out of the muffler and call it good.
jimmydean is offline   Reply With Quote
Old 12-01-2006, 12:54 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Man, that is going to be LOUD. I want to get it as far out the back as possible.
-Chris
Old 12-01-2006, 01:00 PM   #4
Chops_by_Chase
Chops_by_Chase's Avatar
I am doing shorty headers, and 3 inch all the way out... i put in a tubular crossmember which will give me some room to run the exhaust through, but i also put in the under bed gas tank which wil make it hard to run the pipes out the back. If i can find some mandrel bent 3 inch tubing i will piece it together and then pull it out and tig weld it. If i can get my motor back in soon, I will get some pics of the exhaust. if i don't and any one else has pics i would also love to see them. could save me allot of time.
Chops_by_Chase is offline   Reply With Quote
Old 12-01-2006, 01:14 PM   #5
98L150
///Relaxed Atmosphere
98L150's Avatar
I have soempics of the stainless exhaust htat was done on the blue truck that I help put together that was completed backin 2005. Here are the pics I have have at work that show the block hugger headers. Ehaust was 2.5" stainless steel tubing with st/stl Borla mufflers.
Jeff
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 12-01-2006, 01:46 PM   #6
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
That looks like Porterbuilt's dropmember in that truck.....
I'm working on the same problems w/ exhaust right now. I'll most likely be going with the ECE drop x-member and will run the pipes through that and then dump them right in front of the rear end. The currently run under the x-member and I have been dragging the snot out of them. I've got a brand spankin new set of Sanderson jet-coated blockhugger headers waiting to go in but I need to get some other things worked out first.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 12-01-2006, 02:16 PM   #7
jimmydean
jimmydean's Avatar
I plan on running the Summit welded mufflers with 2.5 tubes. A freind of mine put the same setup on a 383 in a '64 SS Impala and it was perfect. Nice and low rumble from 0-2500 rpm with your foot off, but stomp on it an look out.
My truck is running ghetto straight pipes and cherry bombs now, so I doubt it could get much louder.
Old 12-01-2006, 02:44 PM   #8
lvscott
Thats a Jim Meyer front end. Very pricey. I looked in to it before I found Nathens Dropmember. That crossmember requires you change everything on your front suspension.
lvscott is offline   Reply With Quote
Old 12-01-2006, 05:37 PM   #9
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I will be using shorty headers from a camaro and dumping it right behind the cab. Before I took it apart for the Z, I had the stock center dump manifolds with a 90 from Autozone and a piece of pipe and dumped it just behind the cab. I made it myself and it worked fine. Pretty cheap too.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 12-01-2006, 06:46 PM   #10
Damian
Damian's Avatar
im not bagged but it's all above the frame
yea i have a little oil under there
Damian is offline   Reply With Quote
Old 12-01-2006, 08:19 PM   #11
98L150
98L150's Avatar
Damian that is how my 72 sub's exhaust is done.
Here are some pics of the blue trucks exhaust:
Jeff
72 Suburban
64 Build Thread
Old 12-01-2006, 10:45 PM   #12
Low68
Low68's Avatar
WOW, that is super clean. Does your bed have a step in it?
Build Thread
Low68 is offline   Reply With Quote
Old 12-01-2006, 10:51 PM   #13
98L150
98L150's Avatar
yes the bed does have a stepp notch in it.
72 Suburban
64 Build Thread
Old 12-02-2006, 12:39 AM   #14
PBFAB.COM
PBFAB.COM's Avatar
Here's some pics of the exhaust on Dino's 66. It's dual 2.5" fabricated exhaust (180 mandrels cut and TIG welded together) into a 4" Flowmaster 'Super Comp' muffler and turned down and out behind the cab. It's loud... but cool!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-02-2006, 03:26 PM   #15
XXL
Señor Member
XXL's Avatar
Mine is a 6-banger, so only one exhaust, but you could repeat on passenger side for duals.
I routed my head pipe to the outside of the frame rail just as quickly as possible behind the front wheel (where the frame comes up at an angle to the front xmember). Once outside the frame, it's pretty much a straight shot all the way back to in front of the rear wheels. The rocker hides everything (my muffler is under the cab, behind the rocker because there's not much place after the cab for a muffler on a stock frame stepside. Since going to the fabricated back half, I'll be able to put as big a muffler as I'd ever want just outside the frame rail either in front of or behind the axle.
XXL is offline   Reply With Quote
Old 12-02-2006, 03:27 PM   #16
XXL
Señor Member
XXL's Avatar
Oh, mine currently dumps like the last pic in Porterbuilt's post just above.
Old 12-05-2006, 11:26 AM   #17
Low68
Low68's Avatar
Anyone with bags have their exhaust run all the way back behind the rear wheels?
Build Thread
Old 12-05-2006, 12:35 PM   #18
XXL
Señor Member
XXL's Avatar
Possibly, but the problem is that... for a standard bag setup with CPP notch, the axle bottoms out on the notch, which leaves less than 2" of clearance between the axle and the bed floor. So to run all the way to the back, you'd be laying on the exhaust instead of the axle.
Old 12-05-2006, 01:51 PM   #19
el curioso
el curioso's Avatar
hEY 98L150 I think you forgot the calipers!!!!
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 12-06-2006, 12:42 AM   #20
04 orange
04 orange's Avatar
What headers are yall running when the truck is bagged.
04 orange is offline   Reply With Quote
Old 12-06-2006, 09:25 AM   #21
Inthuwind
Straight jacket required
Inthuwind's Avatar
I heard Sanderson C5 full lengths will work on Big Block and bagged.
1968 C10 Short Stepper
350/350 A/C P/S P/B Front disc
3/5 static/ 12bolt rear 3:73
1979 Pontiac Trans Am
10th Anniversary/455/4spd
2011 H-D Street Glide - CAMMED n lowered
Dad always said,"Son, if you can't be good...be good at it."
Inthuwind is offline   Reply With Quote
Old 12-06-2006, 11:34 AM   #22
FnLow69
FnLow69's Avatar
either shortys or block huggers
FnLow69 is offline   Reply With Quote
Old 12-12-2006, 09:50 PM   #23
bodydropped68
bodydropped68's Avatar
here's one pic i have of my exhaust were it exits,i'm running block huggers and it runs on the outside of the frame then between the frame and rear tyre's following the frame kickup over the axle.
bodydropped68 is offline   Reply With Quote
Old 12-12-2006, 10:58 PM   #24
Elsie72
Chinook Arch
Elsie72's Avatar
I've got the same setup as what jimmydean was talking about, but I'm still running stock exhaust manifolds.
It's pretty loud in the cab, except at about 40kph, and at about 70kph. The Hooker Aerochambers seem to hit a resonance there, and it's quite calm. But at highway speeds, it gets pretty loud when it's running at 110kph!
When I get headers, I'm going to redo the whole thing, cutting /bracing the crossmember, putting in a cross-over, and running it over the axle.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
Old 12-12-2006, 11:58 PM   #25
Shane
Shane's Avatar
3/4 length Dynomax for Chevelle/Malibu ...
Shane is offline   Reply With Quote
