12-22-2006, 11:13 AM | #1 |
Junior Member
Lights Flicker - upgrade alternator?
My headlights flicker when driving and dim when idling, and I was wondering if an upgrade to the alternator is the fix? 69 C10 with what looks like good original wiring. I looked at the thread below about swaping to internal regulated alt, but was wondering if a one-wire alternator would be easier and work as well?
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible |
12-22-2006, 11:16 AM | #2 |
Questionable
Re: Lights Flicker - upgrade alternator?
Before you do anything, I would do the "relay" mod on your headlights if you haven't already. There is a writeup about this in the FAQ section. Headlights will never be dim again, and it might fix your problem.
Otherwise, might wanna test your battery first. Then check your voltage regulator, then have the alternator tested. You can have the alternator and the battery tested free at your local auto parts chain store.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
12-22-2006, 12:08 PM | #3 |
flickering i'd clean and tighten contacts and most importantly clean and tighten ground wires
12-22-2006, 01:26 PM | #4 |
Born Psycho
my daily driver was doing the same thing until i put on a later alternator with a built in regulator. we did it at work one morning when it was slow, only took a few minutes to wire it and i love the difference.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
12-22-2006, 01:53 PM | #5 |
mine dont flicker but they god dim at an idle because of my cam
