Old 11-13-2002, 09:42 PM   #1
Big Paul
Iamnotanofficerofthelaw
Big Paul's Avatar
Question HMMM, maybe you guys can help. Cab supports?
What would I use to hold up the cab when changing the rubber supports?
My old ones squeak like mad, and are all cracked up and about ready to fall apart.
I know alot of you guys have done restos or done this type of thing.
Can I just use my floor jack to support the cab? Whats all involved. Removing and installing the new supports should be a piece of cake. I'm just worried about how to hold the cab up.
~Paul~
'96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock
'87 S-10 Ext Cab- 2.8L/700r4
KIA Caught fire 12/7/03
Big Paul is offline   Reply With Quote
Old 11-13-2002, 10:49 PM   #2
75stepside
*Proud Member*
75stepside's Avatar
since your truck will be all together, this first idea may not work, but check out how i REMOVED my cab:
http://merlin2.alleg.edu/student/t/t...os/cablift.jpg
i'd say for your purposes, use a floor jack after you have the bolts loose. just make sure you use a plank or block so that you have a bigger area to push up against the cab. the bare cab itself is probably about 400 pounds... probably 1000 w/ the doors and stuff... but you're fenders are bolted as well... but a floor jack should work fine, i'd think.... ask someone who did a lift kit!... they'd know....
75stepside is offline   Reply With Quote
