Old 01-28-2007, 12:29 PM   #1
rage'nrat638
rage'nrat638's Avatar
69 3/4 ton power drum brakes pro valve pic request
hey guy's i am going to be installing the correct booster on my truck..
some one along the line changed mine to a 1/2 ton model.
i need a picture of the pro valve and line connections of a 69 c20 so i can do this right one time..
here's a few pictures...i will be installing a Bendix (cardone) REBUILT BOOSTER
i have got the correct brackets after many moon's of searching..
the 1/2 ton booster has a longer shaft sticking out the back than the 3/4 ton does. i just want to see the line connections and provalve used.
THIS WILL CONVERT from a single diaphragm to a double diaphragm
1969 C-20 POWER DRUM BRAKES PRO VALVE PICTURE REQUEST
THANKS IN ADVANCE
rage'nrat638 is offline   Reply With Quote
Old 01-28-2007, 03:52 PM   #2
rage'nrat638
Re: 69 3/4 ton power drum brakes pro valve pic request
ttt
Old 01-28-2007, 04:30 PM   #3
GMCBubba
GMCBubba's Avatar
not sure if this helps or not. i actually just changed out the master cylinder today. no power, though.
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 01-29-2007, 08:47 PM   #4
rage'nrat638
to the top. TTT
PLEASE anybody?
Old 01-29-2007, 09:06 PM   #5
john
member #16
john's Avatar
I dont think there is any diff between power and non power. That block basicly splits the front and rear and houses the warning light switch. The four wheel drum brakes do not use a proportioning valve. I think thats how it works. Even the disc trucks use the same prop valve between 1/2 and 3/4 ton. They are just plumbed different. If yours looks like GMCBubba you should be good to go.
john is offline   Reply With Quote
Old 01-30-2007, 04:54 PM   #6
meathead95
computer illiterate
meathead95's Avatar
my 70 k20 has a prop valve and so does my 66 mustang so yes drum/drum systems do need a valve. the one in gmcbubba's photo looks just like the one on my 1970 k20
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 01-30-2007, 08:53 PM   #7
Bob Moore
Marc - what specifically do you want to see?
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-30-2007, 09:59 PM   #8
rage'nrat638
Thumbs up Re: 69 3/4 ton power drum brakes pro valve pic request
the valve and the way the lines are hooked up.
i ordered the booster last friday should be here soon, i just want to be ready.
i am hoping i don't have to swap lines from front to rear on the master cyl.
Old 01-30-2007, 11:12 PM   #9
pierce
pierce's Avatar
rage'nrat638
Here's a couple pics from my 69 3500 it's got factory pwr brakes and 4 drums. These were shot in the fffffreezing dark of night, good thing the flash worked. see if this works...
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 01-30-2007, 11:20 PM   #10
rage'nrat638
thanks man..thats the stuff..from the looks of it..i think my master cyl will work i just need to change the booster
thanks everyone!!! and of course i will save the pictures for future use
Old 01-31-2007, 07:54 PM   #11
rage'nrat638
got the booster today...i am good to go. no need to reverse the lines. my master cyl will fit right on the new booster. thanks for the help guys. i will post pictures when it's installed for a FYI..
I HAVE NO CLUE why someone would have installed a 1/2 ton booster on my truck single diaphragm. this new one is a dual diaphragm
Old 02-02-2007, 07:29 PM   #12
rage'nrat638
got this dude installed every thing fit perfect. thanks to a board vendor for getting me the correct firewall bracket set-up.
installed the correct booster on my 69 c-20 that has not been correct for the four years i have had the truck.. it's great to have this problem strightened out.
Old 02-03-2007, 05:09 PM   #13
GMCBubba
GMCBubba's Avatar
what is that you have installed just south of the proportioning block in the brake line?
looks like a nice, easy swap. will it be that easy to just add power brakes to my manual set-up?
