Old 02-15-2007, 10:27 PM   #1
xtreme80
Wishin' I had more money!
xtreme80's Avatar
Ignition kill switch?
I know how to do it on an EFI car, but what about a carbbed truck? With a mechanical fuel pump, I cant do a fuel cutoff switch, but I need some way to cut power so the truck won't start.
Anyone have any ideas how this could be done?
xtreme80 is offline   Reply With Quote
Old 02-15-2007, 10:57 PM   #2
84 400
Sb 400 club
84 400's Avatar
Re: Ignition kill switch?
Since you can't do the fuel pump then go for the coil. If the coil has no power the truck caint start.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 02-15-2007, 11:01 PM   #3
xtreme80
xtreme80's Avatar
So what would I do just wire an inline switch into the main coil wire? I'm still fairly new to small block chevys, since I come from a long line of nissans. Would I have to use a solenoid for the switch?
Old 02-15-2007, 11:01 PM   #4
Staceydude
Staceydude's Avatar
Battery kill switch.... mounted anywhere you wish...
http://www.jegs.com/webapp/wcs/store...52485_-1_10367
http://www.jegs.com/webapp/wcs/store...45318_-1_10367
http://www.jegs.com/webapp/wcs/store...45298_-1_10367
Staceydude is offline   Reply With Quote
Old 02-15-2007, 11:08 PM   #5
xtreme80
xtreme80's Avatar
See here's my problem. I'm just finishing up my crate motor install. Ive also got alot more money invested into the tranny and drivetrain of this truck. But the problem is my ignition lock cylinder doesn't work, so the truck can be started without a key. I need a switch that's small and easily hidden so I can kill the power. If I could afford that switch, I would just go ahead and buy a new lock cylinder, but being a broke 20 year old with too many bills to pay and in debt for the new engine, I just can't spend that kinda money. I rreally wish I could though.
Old 02-15-2007, 11:15 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Put a hidden toggle switch on your neutral safety switch. The truck won't turn over at all unless the switch is on...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-15-2007, 11:22 PM   #7
xtreme80
xtreme80's Avatar
So you're saying that when the truck is in drive, the NSS is "off" and when in park, it's "on"?
If that's the case, I could wire it up so that the switch is "off" when Im not around, and i have to turn it "on" to start the truck.
Did I follow you correctly?
Old 02-15-2007, 11:26 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
That is correct. The NSS is open unless the truck is in park (or neutral) and won't allow power to the "start" circuit.
Articles-
"Refining Sierra"
Old 02-15-2007, 11:29 PM   #9
xtreme80
xtreme80's Avatar
Mine is only open in park, not neutral. Weird...
Where would I find the main power wire for the NSS? Would it be behind the column?
Old 02-15-2007, 11:54 PM   #10
HotRod73
HotRod73's Avatar
i had a toggle switch mounted in the ashtray (so it was hidden) on the 78 bonanza project it would cut the power to the coil and wouldnt let it start...
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
Old 02-16-2007, 01:55 PM   #11
Prerunner1982
Prerunner1982's Avatar
The kill switch to the coil will let the engine turn over but not start, the switch to the NSS wont let it do anything. I had one to the coil on my 82.. You could even do both for the extra security..
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-16-2007, 02:06 PM   #12
xtreme80
xtreme80's Avatar
But how do I wire it up to the ignition? Do I just wire it to the main coil wire? If I do that, won't I need a solenoid since that's a pretty heavy duty wire?
Old 02-16-2007, 02:59 PM   #13
piecesparts
Parts and more parts
piecesparts's Avatar
Look under the dash (right at the column where the ignition switch is) at a heavy PURPLE wire, that is the power wire that you would cut. It is used for the alarm systems as a disable to the starter. OR---go to the NSS switch and just cut the one to coming from the switch and put a toggle switch in it's line circuit. A lot of pickups in the 80's era had a wire that went to the clutch pedal (if installed), if there was no pedal, then the wires wire connected in a splice. "Use that wire for your break in the line"
