Old 02-19-2007, 05:24 PM   #1
djohnson
Nutserts on core support?
Can anyone tell me where to find "nutserts" like the factory used on the core support where the upper radiator support mounts (This is on a 78 K5)? How about a procedure for replacing them?
djohnson is offline   Reply With Quote
Old 02-19-2007, 06:29 PM   #2
bigblock73
yeller
bigblock73's Avatar
Re: Nutserts on core support?
Typically there are capture nuts on the bottom side of the core support, and the upper radiator mounts screw into them. On my truck, which was originally small block powered, I had the small radiator and the capture nuts were on the core support on the inside of the engine compartment. Now that I have switched to a big block, I had to mount the BB mount to the topside of the core support...the problem, there are no capture nuts there! To solve my issue, I used well (expansion) nuts and mounted it that way. Not quite factory, but works perfect and doesn't require I weld nuts to the underside of my already painted, assembled, and installed core support. If you need a picture, I can snap one later tonight. Hope this is what you were looking for.
bigblock73 is offline   Reply With Quote
Old 02-19-2007, 10:06 PM   #3
dswancutt
They are still available from GM. Part Number 3792287.
dswancutt is offline   Reply With Quote
Old 02-19-2007, 10:13 PM   #4
djohnson
Great! Thanks for the information.
Anyone know how to install them without the special tool?
Old 02-19-2007, 10:18 PM   #5
bigblock73
yeller
bigblock73's Avatar
Anyone have a picture of a "nutsert"?
Old 02-20-2007, 01:28 AM   #6
dswancutt
I need some for my project. I will try the dealer in Kearney Neb and see if by some odd chance, they have some in stock. Most likely I will have to go to Sutton Neb to pick them up. I used some on my doors for the mirrors, and all that I did was hold them as I started the bolt, and once they had flared enough behind the panel to grab, they tightened right up. I am not sure if these work the same way.
Old 02-20-2007, 07:28 AM   #7
bigblock73
yeller
bigblock73's Avatar
GMpartsdirect has them, about $2 a piece. Can you get a pic once you get them?
Old 02-20-2007, 11:37 AM   #8
dswancutt
If they don't have them at the Kearney dealership, it might be a week or so. But I will shoot some pics one I have them.
Old 02-20-2007, 01:08 PM   #9
Restrorob
The One And Only !!!
Restrorob's Avatar
Great, I'd like to see them also...
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 02-23-2007, 11:35 AM   #10
dswancutt
Sorry guys, struck out on the nutserts this week. Will let you know when I get them
