More engine compartment and "what is this"?
Ok guys,
here are some more pics. I have been reading my manuals, chiltons and haynes, have not picked up a factory service manual YET... Anyway, any help in identifying these would be a big help. On the carb pic, that white/off white looking connector (circled in red)...I barely touched that thing and the clip broke, so I zip tied it for now. Have no clue what it is/does... The others...I have looked on the wiring diagrams, but they did not help me much, one diagram said oil pressure sensor... One way or the other, I will know what these are and what they do. Hope this post helps others as well. Thx Drivers side: ![]() Behind carb: ![]() Passenger side: ![]() Carb: ![]()
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
The Crazy Machanic
Re: More engine compartment and "what is this"?
first pic on is temp sensor , 3rd pic is for oil probly tell u if ur low no clue i just hook it up
The One And Only !!!
The one in red is the map sensor, Yellow one is the AC idle solenoid to up the idle when the AC is turned on.....
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
thx guys, keep it coming!
Dirteh Kitteh
One of the ones by the exhaust manifold (gray or orange) is going to be your ignition knock sensor.
Purple in the last pic is a temp sensor.
Darrin 1955 Willys CJ-5 all original and the oldest CJ-5 on the road. 2001 Dodge Neon (wife's car) 1995 Jeep Grand Cherokee Limited Edition SOLD 1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD 1993 S-10 4X4 Tahoe SOLD ![]() ![]() RIP ESLL Last edited by Mickey_D; 02-23-2007 at 09:24 PM. |
Parts and more parts
The third one is the Knock sensor on the right hand side of the motor.
Been looking online for a "replacement" connector plug for this. I must be searching wrong, but map sensor on all the big auto parts sites come up with one of those black rectangular maps with 2 mounting screws, nothing like the one pictured. Any ideas where I can get a new connector for it, or if I have to buy a new map, that's fine too.
Insert Witty Text Here
The red one isn't a MAP sensor. The truck does not have one in '86 (not sure about CA emissions) It controls a two stage accelerator pump or something like that. The temp switch in purple controls it.
Slonaker |
Sorry....That is not the map, That's the pump solenoid. I've only been out of the auto biz for 16 yrs. Try your local junk yards for a plug or try the dealer.
I don't want to step on anybody's toes here, but... the "thing" circled in red is the mixture control solenoid for the carb... Try researching for a conector using this info.
Hope this helps. Al
_____________________________________________ 97 K1500 Tahoe 5.7 Stock "Driver" 78 swb C10 Silverodo/ 350cu. dual Flowmaster's, MSD cap, and wires. "Project" ![]() LONG LIVE AMERICA!! ![]() |
yes 86 california models have a map sensor. From the looks of your carb you have an e4me (computer controlled carb). Which proboably means your car has ca emissons set up. the pump solenoid controls regulates your trucks engine at idle. Looks like you have a dual air smog tube set up as well.
Maybe that is what the blue one is in the second pic.....
thx, googling now...
#15 |
if it has a small vaccum hole leading into it then it proboably is the map sensor.
#16 | |
but thx, you guys are "learnin'" me tonight. ![]()
#17 |
you do have a computer controlled carb though. A few states have same set up as california cars as far as smog goes. Just the tests are not as harsh as cali. I dont know if georgia is one of them. you just have one smog air tube on each side? It looks like it.
#18 | |
Where would the carb ecm be mounted?
#19 |
its usually mounted on the firewall...Look under your steering will in the cab...see if you have a aldl hook up. looks like a plug ..lots of lil prong holes
#20 | |
![]() ![]() Al
_____________________________________________ 97 K1500 Tahoe 5.7 Stock "Driver" 78 swb C10 Silverodo/ 350cu. dual Flowmaster's, MSD cap, and wires. "Project" ![]() LONG LIVE AMERICA!! ![]() Last edited by 78Chevy; 02-24-2007 at 12:12 AM. Reason: mis-spelling |
#21 |
any of you running thorley headers?
#22 | |||
As for the red circle in the last photo:
I know that connecter looks just like the connector for the mixture control solenoid, on the computer controlled carburetors but, on a 1986 full size pickup they had a solenoid control dual capacity accelerator pump and that is what that connector is for. Notice there is no connector on the front of the carb for the TPS for a computer controlled carb. Also notice no idle air bleed screw or place for it. Quote:
dual capacity accelerator pump and the temp switch for it. Quote:
First picture gray circle, I agree with Srubydo1986 , is the temp sender for the dash. Last edited by ChevyTech; 02-24-2007 at 01:17 AM. |
#23 |
[QUOTE=shrtbx;2045428]you do have a computer controlled carb though. QUOTE]
It is not a computer controlled carb. The electrical connector is for a dual capacity accelerator pump. It is just an '85-'86 thing on trucks. The carb model is an M4MED. You can read about it here: http://www.73-87.com/7387garage/drivetrain/myqjet.htm Try googling for M4MED and see what folks have to say about it. Slonaker EDIT: Thanks ChevyTech. You type faster than I do. ![]() Last edited by Slonaker; 02-24-2007 at 01:14 AM. |
#24 |
are you saying for all 86 full size trucks there are no map sensors. My 86 silverado has one. Its a ca car. california pollution controlled carbs came with the e4me.
#25 | |
[QUOTE=Slonaker;2045582]
