Old 03-18-2007, 06:48 PM   #1
marvxyz1
marvxyz1's Avatar
proportioning valve
I am about to install a new generic prop. valve in my 80 GMC. It has rear drums and front discs. Trouble is, I saw someone mention that, whenever the disc brakes are bled you have to compress the rubber cap on the end of the valve. I don't seem to be able to compress this end part . It doesn't seem to budge. Does anyone know anything about this???? Thanks for any info. you can give me on this.
marvxyz1
marvxyz1 is offline   Reply With Quote
Old 03-18-2007, 07:44 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: proportioning valve
The way I understand, The only time you have to push the pin on the valve is if you don't get any brake fluid through the front or rear bleeders. Pushing the pin re-centers the valve. Start bleeding at the R/R then L/R, R/F then L/F.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-18-2007, 07:56 PM   #3
marvxyz1
marvxyz1's Avatar
Thanks restorob, I've never replaced a prop valve, and I don't want to make any mistakes.. marvxyz1
Old 03-18-2007, 08:05 PM   #4
smills78gmc
Subscribing to tread, I am in the middle of a complete front brake overhaul and have run into the same thing. I only get fluid to the left front caliper. By the way, I have replaced mc(bench bled) front calipers, and rotors.
smills78gmc is offline   Reply With Quote
Old 03-18-2007, 08:27 PM   #5
Restrorob
Restrorob's Avatar
You may have a internal collapse in the right hose restricting fluid flow, The proportioning valve determines the amount of fluid sent to the rear verses front.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-18-2007, 08:31 PM   #6
smills78gmc
Are you talking about the hard line at the back of the master cylinder or somewhere towards the back of the truck?
Old 03-18-2007, 08:38 PM   #7
Restrorob
Restrorob's Avatar
OK, I miss read your post. You are not getting any fluid from the other three bleeders correct ? If so you need to check the proportioning valve to see if it's centered, And my other post could apply for no fluid to the R/F.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-18-2007, 08:48 PM   #8
smills78gmc
ok, I will try to center the valve, from what I have read, It seems the best way to do that is with a piece of wood wedged between the frame and the valve. Do you know a better way? Thanks for the help
Old 03-18-2007, 08:55 PM   #9
Restrorob
Restrorob's Avatar
I have just simulated slamming on brakes a few times (hit the pedal hard) and had them re-center them selfs. I have also had to remove the brake warning switch and use a pick to center them.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-19-2007, 09:44 PM   #10
smills78gmc
I put a c clamp on the prop valve to center it. I now get fluid to the rear and the right front. Thanks for the help.
Old 03-19-2007, 10:20 PM   #11
Restrorob
Restrorob's Avatar
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-20-2007, 07:02 PM   #12
smills78gmc
Should I leave the clamp on the valve during the bleeding process or remove it then bleed the brakes? I have been pulling alot of fluid through the rear, but I still have lots of air in the lines.
