Old 05-11-2007, 02:30 PM   #1
atcavage
Too many accessories, too little power
So after failing miserably, I had someone put in my power windows. Add on the courtesy lights, the hood light, the stero, the lighter, and the power locks, I'm out of room in the fuse block.
I need to wire in a few extra circuits, but have no idea how to do it. Could someone recommend a kit that doesn't replace the fuse box and is really easy to install?
Thanks.
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 05-11-2007, 08:45 PM   #2
KFreddy
Active Member
KFreddy's Avatar
Re: Too many accessories, too little power
Really simple run a secondary wire #8 oughta do it, good fo 50 amps From the battery through the firewall and terminate it in a distrubution block. Any Auto stereo store should have them for 10-30 bucks. Then pull several smaller wires out of the distro block to seperate fuse blocks. Nice and neat and will serve your purpose well. Then you can buy my pretty much brand new 140 Amp Powermaster alternator from me and you'll never have issues again
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 05-11-2007, 11:02 PM   #3
wibilly
wibilly's Avatar
i would be taking a trip to the junk yard and looking for a relay - fues panel to mount under thats what i plan to do for headlight relays and any extras i may want to add as i build
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-12-2007, 10:21 AM   #4
atcavage
Anyone recommened a specific brand of distrubution block or can I use one of the cheapo generic ones?
Old 05-12-2007, 10:51 AM   #5
KFreddy
Active Member
KFreddy's Avatar
I think that Walmart carries "Scosche" brand power/ground blocks in there car audio section. It should be 10 to 15 bucks. Short of wanting to get real fancy that one should be just fine.
Old 05-12-2007, 10:27 PM   #6
JoeMamma
JoeMamma's Avatar
Try this one from Summit Racing.
http://store.summitracing.com/partde...rt=PRF%2D70103
Designed to be used as an add-on fuse panel. Can be used with either "Hot" or "Ignition Controlled" circuits.
You must have some automotive electrical knowledge to wire/install it.
I used to design and build custom automotive wiring harnesses for race cars and street rods. From the Summit picture, the fuse block they use looks identical to the custom Delco bolt-and-stack block I have used in the past.
Joe M.
JoeMamma is offline   Reply With Quote
