BAD BOW-Silverado XST
ZZ4 turning over!! Serpetine belt wiring help needed
I need some serious help. My ZZ4 is ready to start up. We can crank it but the wiring is messed up. What color wire goes to the small terminal on the starter? Purple right? Does it connect to the S or R side?
What wire goes to the alternator? From where on the fire wall? I don't have power to anything. Lights, ignition, internal light. How many red wires go the starter? Do they all go do the big connection? I just need the wiring so I can start it up. The wiring harness was cut during removal of the 305. I have no idea where some wires go. ![]() Who wants to bring their truck over so I can trace some wiring???? I can smell fuel after we turned the motor to prime the oil system. So it's ready to fire up!! |
Gentleman Jim Driver
Re: ZZ4 turning over!! Serpetine belt wiring help needed
Purple to S (for start) terminal on the starter. One of the big lugs is connected to the motor itself (probably a solid bus bar) and the other terminal goes to battery + and to the large red wire that goes to the fuse box (and ignition switch from there...).
The alternator charge wire will also be a 10 gage or so red wire and splice into wires that end up going to battery +.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed Last edited by ElGracho; 09-29-2007 at 12:49 AM. |
ElCracho,
Thanks for the info. There is a 10 guage red wire with a little eye connection at the end. The eye is small enought to fit on the starter bolts. Do you know where that wires goes? The wire leads up to the fusable link on the fire wall. The link splits into one of the bulk heads. |
