Removing Timing Cover
I am thinking about removing my timing cover for 2 reasons. One is to make sure I dont have a loose timing chain. Two is that I want to line up TDC once and for all on this motor
![]() Thanks
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Re: Removing Timing Cover
If you loosen the front two pan bolts & carefully pry the cover off, you can re-install it when you are done in there. Make sure you put some silicone on the corners & tighten the pan bolts again after you get the cover back on...
no oil should come out.....
1997 GMC Sierra Ext 1965 Mustang |
Sierra Grande Club
This is what happened when I took my cover off!
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
