Old 10-04-2007, 08:08 PM   #1
JHART
1972 Shorty Owner
JHART's Avatar
Location: Stationed in Cali , born and raised in PHX Arizona.
Header Gasket advice - Which ones are better?
I'm going to be putting in the new exhaust this weekend but i cant seem to find a good gasket. I need thicker ones .... THAT DONT LEAK! I'm tired of damn header gaskets that blow out. So i bought some locking header bolts and now all i need to know is what you guys think i should use for gaskets.
They need to be thicker .... please if you have some time to point me in the right direction i would be thankfull.
Gaskets are for 350 sbc.
If you have some pics that would kick a$$ ... thank you
-Hart
1972 Chevy Shorty C-10- Project In Work
http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project
JHART is offline   Reply With Quote
Old 10-04-2007, 08:37 PM   #2
DieselEater
DieselEater's Avatar
Re: Header Gasket advice - Which ones are better?
I use copper.....they are thin.....but they won't blow out......and they are re-usable if you have to remove headers for some reason.
A..........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 10-04-2007, 08:39 PM   #3
JHART
1972 Shorty Owner
JHART's Avatar
I was looking at those also but i think those will be too thin for my set.
This is killin me .... lol
Old 10-04-2007, 08:51 PM   #4
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I used Percy's Carbon gaskets, they seem to work just fine
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 10-04-2007, 09:03 PM   #5
JHART
1972 Shorty Owner
JHART's Avatar
Do you know about how thick they are?
Old 10-04-2007, 09:13 PM   #6
corn
Just go buy a set of exhaust manifold gaskets & your troubles will be over. Thats all Ive ever had any luck with on small blocks...
corn is offline   Reply With Quote
Old 10-04-2007, 09:14 PM   #7
BCOWANWHEELS
copper is best you can get
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 10-04-2007, 09:19 PM   #8
caminokid
Chevy nut
caminokid's Avatar
I would go with copper. I have the regular exhaust manifold gaskets on my Firebird...and they are blown out already. Why do you need think ones? Did you have some mill work done to the outsides of the heads?
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 10-04-2007, 09:31 PM   #9
1fun71
1fun71's Avatar
I like these the best.. always seal tight and last.
http://www.holley.com/99150AFLT.asp
1fun71 is offline   Reply With Quote
Old 10-04-2007, 09:31 PM   #10
JHART
1972 Shorty Owner
JHART's Avatar
No mill work. The headers are round port and they stand out a little bit from the flange so i think thicker ones will be better. But if you guys think otherwise?
Old 10-04-2007, 09:33 PM   #11
bryanw1968
bryanw1968's Avatar
I've heard copper is good but I haven't tried them yet.
If you are going to use regular gaskets try one of two things.
Either soaking them in water and or vegitable oil first and then put them on.
They'll swell up and adhear to your ports/header primary tubes.
bryanw1968 is offline   Reply With Quote
Old 10-04-2007, 10:02 PM   #12
BCOWANWHEELS
there supposed to stand out, its how they get a sealing surface. do you go back and retighten them several times after you get them hot ?
Old 10-04-2007, 10:18 PM   #13
JHART
1972 Shorty Owner
JHART's Avatar
Well with the old ones yes. But these are the new ones i am putting on that i want to go thicker with.
I think i am just going to go with some basic gaskets and the the lock nuts and see what happens.
Keep the advice coming though so more people can read this and hopefully get something out of it.
I will post pics this weekend with some sound clips of the open headers before i put the mufflers on
Old 10-04-2007, 10:27 PM   #14
1fun71
1fun71's Avatar
try these
http://www.holley.com/99150FLT.asp
Old 10-05-2007, 01:32 AM   #15
jamesi20
jamesi20's Avatar
it took a while,but I am a believer in copper now.
jamesi20 is offline   Reply With Quote
Old 10-05-2007, 03:32 AM   #16
Mudder
Mudder's Avatar
Cut the flanges of the headers and get a set of mainfold gaskets and be done with it.
Mudder is offline   Reply With Quote
Old 10-05-2007, 06:07 PM   #17
corn
Thank you! Finally someone who agrees with me...
Old 10-05-2007, 07:02 PM   #18
wedgemon
wedgemon's Avatar
I agree with CORN & Mudder on this. Cut the flange between each port. (But, not thru any mounting holes!) And get you some cheap A$$ manifold gaskets. Take a quick run and tighten again.
Works great!! Prolly due to less combined flex - each tube can flex individually.
- Dave
Like this...
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
