Old 12-03-2007, 10:52 PM   #1
Chevy Fleetside
Chevy Fleetside's Avatar
Finally the headers are fitted and now
it is time to detail the engine. That is silver duct tape on the headders so I did scratch the bajeebers out of them when putting them in for a test fit. Now I get to pull it all apart again.. Oh the joys of building..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-03-2007, 11:03 PM   #2
L0WRIDE
L0WRIDE's Avatar
Re: Finally the headers are fitted and now
niceeee!!!!
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 12-03-2007, 11:23 PM   #3
steverino66
Curious - looks like you used the rear 2 holes on the frame - have you had any clearance issues with dist. cap at firewall? HEI or points?
Also, looks like your frame may have been trimmed a little at the motor mounts - has it? I ask because I'll be tackling this same install later this winter.
steverino66 is offline   Reply With Quote
Old 12-03-2007, 11:58 PM   #4
Chevy Fleetside
You need to look at this thread. I had to cut the firewall to get the engine to sit back farther. http://67-72chevytrucks.com/vboard/s...d.php?t=259536 .. It is an 89 year model bb and has the small HEI distributor. There would be plenty of room for an HEI back there though, it just looks worse in the pictures.. Yes I did trim the frame where the mounts are. That is what the 67-72's are like.
Old 12-05-2007, 02:18 PM   #5
Iron-Butt
454 club
Iron-Butt's Avatar
I used those same engine mounts. I used the stock manifolds instead of headers. I did not have any clearance problems with the hei.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 12-05-2007, 06:04 PM   #6
04Xrider
Registered thread killer
04Xrider's Avatar
Wow! For a big block, I see more ease at getting to those plugs and header bolts then I have on my small block. Looking good.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 12-05-2007, 06:42 PM   #7
jchav62
1962 C-10
jchav62's Avatar
Nice!! Good job...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
