Old 03-01-2008, 04:10 PM   #1
chromyelow1
OPS GUY
engine cleanup...
my engine is so covered in oil that i would really like to clean it up. Any ideas with out having to take out the engine?
chromyelow1 is offline   Reply With Quote
Old 03-01-2008, 04:34 PM   #2
rod86
great southern land
rod86's Avatar
Re: engine cleanup...
get a can of degreaser and spray it on scrub with a little brush on hard spots then hose off... just blow all watter out of low ares on the engine an avoid getting the electrics wet.
rod86 is offline   Reply With Quote
Old 03-01-2008, 05:56 PM   #3
slug
slug's Avatar
go get some castrol super clean, its in a purple bottle. spray your engine with it and let it soak for a while(untill it dries) then go back and spray it down again, then wash the engine with a high presure washer.
slug is offline   Reply With Quote
Old 03-01-2008, 10:28 PM   #4
SRH916
1975 C-10 Silverado LWB
SRH916's Avatar
shouldnt you cover the carb with a plastic bag or something first? Its ok to just go through with a pressure washer?
1975 LWB C-10 Silverado
- Stock
- "BIG 10"
- 4 Bolt 350 "Brand new" 1200mi
- THM-375 "Brand new w/trans cooler" 5000mi
1995 Ford Lightning
- Bone Stock
- 351W
- Vortech??
SRH916 is offline   Reply With Quote
Old 03-01-2008, 10:46 PM   #5
swb85
On a budget like Fred Sanford
swb85's Avatar
^^^Yeah, you don't want to get any water down the carb....a plastic bag or a few oily rags will do the trick.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 03-02-2008, 01:09 AM   #6
Malo83
Cruzzzn' Vet
Malo83's Avatar
X2
Malo83 is offline   Reply With Quote
Old 03-02-2008, 03:02 AM   #7
knightlife
Dark Heart Motorsports
knightlife's Avatar
plastic bag the carb and dist...
then seafoam the entire motor inside and out (yes you can run it through your engine too... thats the great thing about seafoam).
change oil, after washing down the exterior of the motor and you should be good to go.
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
Old 03-02-2008, 03:42 AM   #8
85gmcguy
Plays with trucks
85gmcguy's Avatar
I use the Super Clean and one of those $100 1300 psi pressure washers. Just cover the carb and dizzy, If it's really thick, clean it while the engine is warm (but not HOT).I use a garden sprayer to spray on the cleaner ( no pumping on a trigger and it's all-position) May take 2 rounds, may have to scrub/scrape the extra heavy stuff, but it's worth it to be able to work on a clean motor.
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 03-02-2008, 04:09 AM   #9
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
ive used a pressure washer on mine , several trucks and its always worked well.. you can use any decent commercial grade cleaner even gunk is good.. like others said cover the carb and distributor well and ya should be good to go
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
