Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-18-2008, 01:31 PM   #476
jb4short
Damn Yankee
jb4short's Avatar
Re: PO has me PO'd
Originally Posted by vtblazer View Post
Wondering why there's a hole in the cowl...?
What's the install 'skill' level feeling like Jim?
Could this piece be used for a guy's first project?
Kurt, I cut those holes to blast inside
jb4short is offline   Reply With Quote
Old 04-18-2008, 01:32 PM   #477
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by Chevyman63 View Post
Looking good Jim...nice work.
Thanks Tim
Are ya talking about the hole in the air box? If ya are, that was there when I got here...
Skill level 0-10, 10 being the hardest, about a 5. I have more problems with a and b posts lower patch panels. If the PO hasn't made any patches it's alot easier. When ya get into a factory spot weld it's alot easier. If ya can take a spot weld apart without destroying the metal your trying to save, you can do this, and that is easiest if you make the pc. your trying to remove flat( cut away all metal till you have a ribbon of metal with the spot weld in it), then just use the 4 1/2" grinder to remove the spot weld, then move on to the next one, prying up slightly
I spent about a week and a half cutting out the old floorboard, plasma woulda helped. You can reinstall floorboard with plug welds, so you don't really have to know how the weld, if ya can fill in holes with a mig. You're dealing with a factory seam, front and rear, so it makes it easy to line up flanges (before I started, I painted the seam area, so it showed a line to match up) should also be less welding then a floor patch, if you consider total distance tobe welded
Yes, depending on his ability, but I would recommend this as an entry level, far less fitting and cutting, fitting and cutting, fitting and cutting...So far all I did was cut out old floor, pop in new
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 04-18-2008, 01:51 PM   #478
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Makes sense due to the nature of the beast, I was just curious.
Will this cab be dipped or sprayed for the initial primer?
If you pry open the seam on the bottom of the cowl, between the spot welds, it will help drain better.
The stock weep holes typically gets clogged up, that's when the problems start.
vtblazer is offline   Reply With Quote
Old 04-18-2008, 02:23 PM   #479
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: PO has me PO'd
I can see it now...Jon sells the part and offers to fly Jim to the customer's site (of course on the customer's dime) for the install. This would be great, but where do I fit in? Ah yes, Jim, you'll need an agent! And Kurt, hmm, well we'll have to have a west coast installer as well as an east coast installer! I think this is a great idea.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 04-18-2008, 02:32 PM   #480
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Works for me, but what is your percentage rate?
SAFETY FIRST
AS usual, off topic
Jim
Old 04-18-2008, 02:42 PM   #481
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
Maybe I can convert the percentage to beer...hmm.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 04-18-2008, 02:48 PM   #482
jb4short
Damn Yankee
jb4short's Avatar
Re: PO has me PO'd
Kurt- I've got three cabs here all with the same issues in that part of the cowl. I'm actually thinking we'll cut it off cleanly and fab a new one and send this out to explore making a patch panel from just below the fender bolt hole to the bottom. We have a similar piece already for the '73-'87.
PS: I get 8% of Jim's take
Old 04-18-2008, 03:03 PM   #483
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Dude, I can see the three of us working for beer money, our shop would have to be on a beach somewhereRetirement? Can you say Margorettaville
SAFETY FIRST
AS usual, off topic
Jim
Old 04-18-2008, 03:06 PM   #484
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Great!!, less work for the installer You mispelled that, I think you meant 8% of Tim's take
I can't talk anymore, I'm supposed to be up in the middle of NJ
SAFETY FIRST
AS usual, off topic
Jim
Old 04-18-2008, 03:18 PM   #485
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
I like the idea A LOT! All except for the 8% thing.
I've got to go to work too.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 04-18-2008, 03:34 PM   #486
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
If I sit here much longer the Boss is going to yell! We'll work on that 8% thing. Shop on the beach
SAFETY FIRST
AS usual, off topic
Jim
Old 04-18-2008, 03:38 PM   #487
jb4short
Damn Yankee
jb4short's Avatar
Re: PO has me PO'd
I homebrew so there's no shortage of motivation at my house
Old 04-18-2008, 05:02 PM   #488
Yukon Jack
Yukon Jack's Avatar
Re: PO has me PO'd
That complete floor repo just blows my mind!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-18-2008, 06:23 PM   #489
Blizz
Blizz's Avatar
Re: PO has me PO'd
i just need someone to do this on a blazer so i can see how to do it what with bracing and all.
'72 K5 CST Blazer 4x4 in perpetual progress
'96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon
Blizz is offline   Reply With Quote
Old 04-19-2008, 01:04 AM   #490
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I only used bracing so as not to collapse the roof, should be easier on the Jimmy/Blazer, since that won't be a concern...
I say take the front clip off, cut the floor strait across. You may not need to raise the bed, since the floor pan mounts to the step up. Clean up the factory seam(front and rear). You will have to modify the rear of the floorpan some. Put the cowl/windshield back on zip screw both ends and check door alignment. If they line up, mount your rockers. I think bracing would be in your way, but that's just me. This floor pan is extremely strong. I have about 20 zip screws holding it together up to this point
SAFETY FIRST
AS usual, off topic
Jim
Old 04-19-2008, 03:23 AM   #491
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I was working on removing the cowl area today, so I thought I'd post up some pics of spot weld removal
This is the area of making a ribbon of the sheet metal, cutting the top and bottom so your left with a 1" pc. with the spot weld in the middle
SAFETY FIRST
AS usual, off topic
Jim
Old 04-19-2008, 03:29 AM   #492
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
SAFETY FIRST
AS usual, off topic
Jim
Old 04-19-2008, 04:06 AM   #493
Big J
Its lookin' like a Blazer!
Big J's Avatar
Re: PO has me PO'd
That looks awesome man. Nice job.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 04-19-2008, 04:31 AM   #494
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thank you,but you outwork me hands down. Nice progress on your truck. I haven't dun anything to mine in 3 weeks
SAFETY FIRST
AS usual, off topic
Jim
Old 04-19-2008, 04:53 AM   #495
Chevyman63
Chevyman63's Avatar
Re: PO has me PO'd
I couldn't agree more...nice work Jim.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 04-19-2008, 05:42 AM   #496
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I think the props should go to Tri-Pro Automotive for making this piece available to us...
Thanks Tim
SAFETY FIRST
AS usual, off topic
Jim
Old 04-19-2008, 12:54 PM   #497
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Why the need to remove the firewall piece?
Rust reason's or are you installing a shaved/different part?
Cool work J.
Old 04-19-2008, 01:40 PM   #498
jb4short
Damn Yankee
jb4short's Avatar
Re: PO has me PO'd
Kurt- there are rust holes in it; just hard to see in the pictures. Most of the holes are down low near the mating flange for the floor. It's apart, we have the new firewall so we figured why not replace it and know we don't have any issue with rust to deal with.
Old 04-19-2008, 01:47 PM   #499
vtblazer
vtblazer's Avatar
Re: PO has me PO'd
Yeah, thought that was the case but had to ask just in case you guys were sneaking something in and trying out a new cool piece.
I'm bringing home another blazer today...wanna try the floor in the real deal?
Edit: Got the body mount on Tuesday, thanks.
Old 04-19-2008, 02:06 PM   #500
jb4short
Damn Yankee
jb4short's Avatar
Re: PO has me PO'd
I'll talk to Doug about selling you one at wholesale if you'll document what you do to install it
