Old 05-30-2008, 11:49 PM   #1
Skeeter Dewgun
Smile 6 cylinder help
My 1959 chevy apache has a 235 6 cylinder in it and i need some help with it. It bogs down and misses on the straits when you give it about half throttle but when you come to a hill it runs perfect. I've tried everything I could think of but I can't get it to run right. Any suggestions would be appreciated.
Thanks,
Skeeter Dewgun
Skeeter Dewgun is offline   Reply With Quote
Old 05-31-2008, 06:12 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 6 cylinder help
Have you cleaned out the tank?
Have you cleaned out the carb bowl?
Hows the oil pressure on the flat and up hill?
Old 05-31-2008, 07:32 AM   #3
mylow53
mylow53's Avatar
Re: 6 cylinder help
check for a vacum leak it will mess with the air fuel mix and bog down.. maybe a hose moves when going up hill... does it have vacum windshield wipers?
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 05-31-2008, 06:42 PM   #4
Skeeter Dewgun
Re: 6 cylinder help
yes it has vacum wipers. I'll have to check all the vacum lines out. I'll also look and see what the oil pressure is on the hills and on the flats. Thanks for the suggestions
Old 06-01-2008, 03:32 AM   #5
55dude
55dude's Avatar
Re: 6 cylinder help
plug off the vacuum lines going to the wipers and see if it makes a difference. if no change i would suspect dirt ao weak acc. pump in carb
55dude is offline   Reply With Quote
