Old 05-02-2008, 11:40 PM   #26
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Headlight Relay Upgrade
Originally Posted by jayharrell View Post
Where did you get that junksion block longhorn?
That was Rollie396's post, not mine. Although, i would say go to the junk yard. There's a million of them in there.
I don't have any photos of my set up, and most of it is hidden under the second battery in the longhorn, so basicly, I ain't getting any photos either. When i get around to doing the burb... I'll try to do a FAQ thread, and it'll certianly bbe seen on here, and highlights in my build thread.
Old 05-03-2008, 03:13 AM   #27
Rollie396
someday it will be done!
Rollie396's Avatar
That's actually a 30 amp breaker.I got it at Napa,but Longhorn's suggestion is a good one as well.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 05-03-2008, 03:14 AM   #28
Riveted1
Tasty Cakes!
Riveted1's Avatar
Well, my harness came in today. It will probably work ok, but I'm gonna have to put some black loom on it. That yellow just does nothing for me! The connectors look ok, no different from others I've seen. I have seen better looking relays (Nothing a little paint over the name won't cure!), but hopefully these will work. It will save me a bit of time (as long as it works), but it did leave a little more empty space in my wallet than building my own.
What I do have to laugh about is the instructions. The picture is a poor one, but I'm too lazy to take another one. It just cracks me up that these companies can't find someone that actually knows how to write in English. I've been over there, and plenty of people speak English just fine, so why can't they write it?
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-31-2008, 12:35 AM   #29
Riveted1
Tasty Cakes!
Riveted1's Avatar
Update on this.... that harness IS crap. The wires aren't long enough to go from headlight to headlight. I'm gonna have to finagle it a bit to get it to work right. Why can't people sell stuff that actually works? I mean a couple extra feet of wire is not that expensive, especially after what I spent on this thing. Should've just built my own like was suggested and not try to go the "easy" way. Lesson learned.
Old 05-31-2008, 01:19 AM   #30
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Well at least you have some relays with pig tails, thats worth at least $20
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-31-2008, 01:36 AM   #31
rambler
MOVE OVER
rambler's Avatar
thats exactly the same one I got for the Ford Superduty, I got it to work, but had to do some figuring myself. I got it from LMC as I was in the neighborhood. I didn't have time to build one myself and it worked out ok,, I think the wires are all the same lenght just the connecitons are different base upon the vechicle...
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 05-31-2008, 01:59 AM   #32
Sinister
Between Trucks...
Sinister's Avatar
I have the LMC one, it's tight but you can get it to work. The relays have to be on the passenger side. I ran the main wiring part along with the factory harness across the radiator support.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-31-2008, 03:44 AM   #33
Longhorn Man
from what I understand, the relays are junk too.
Old 05-31-2008, 04:51 AM   #34
chrislehr
Engine n00b
chrislehr's Avatar
So who's gonna step up and make this better?
chrislehr is offline   Reply With Quote
Old 05-31-2008, 05:04 AM   #35
Riveted1
Tasty Cakes!
Riveted1's Avatar
I'll go out there later and spend some more time w/it. I know the relays have to be on the passenger side. But the part where the new harness plugs into my harness ends up right where my battery is. If it had about a foot more wiring, it would plug in closer to the light and out of the way.
Old 05-31-2008, 07:21 AM   #36
cobb_ben
cobb_ben's Avatar
I did this conversion a long time ago to my old '76 C30. It works great. I did it not too long ago to my '69. This time I placed the relays(like 2.50 each from O'rielies) on the inner fender and ran 2 power wires from my secondary fuse panel($13, from O'rielies) I powered that from a 10ga from the junction block. It also powers my electric fan, and I can't think what elese. It looks neat and organized. I just cut the factory wiring right about where the relays are. I took the wire from the switch and went to the relay and the other side to the lights. I have thought about incresing the size of the wires to the lights but they are much brighter and the right is no less bright than the left, that is like 1ft away from the relay, so there isn't power drop. I haven't checked with volt gage, don't have one might get one...
The relays on the inner fender.
The wires in aftermarket loom, I like sprial loom better. The screw in the middle is for the ground.
Notice the anti-freeze jug? Thats my radiator overfill, 3/8 hose from the rad. Notice the collection of paper towels, LOL
The sub fuse panel, it has 6 slots.
Ran the power wires out thru the firewal. Then between inner fender and outer fender.
Ohi the lovely crapy blue over paint by the P.O. uggg, I love the original orange... And the rust ugh. Some time I at least need to sand and paint it so it does not rust...
'69 Chevy C10
400sb-350 crank 400 destroker!!! 377
2.02 dart pro1 alum.heads
msd, holley db
hooker pro-comps-3in exh.
3 spd. saginaw-3.73posi
Flat Bed...want Reg bed...trades?
cobb_ben is offline   Reply With Quote
