Old 05-01-2008, 05:40 PM   #1
bamabaxter
bamabaxter's Avatar
Thumbs up Headlight Relay Upgrade
I know this has been covered before several times on the forum, but I have to say that if anyone has a truck that hasn't performed this upgrade, you don't know what you are missing. It is unbelievable that 2 relays, a circuit breaker, 5 bucks worth of wire, and about 20 minutes could change the lighting and overall electrical system so much. HIGHLY RECOMMENDED!!!!
'72 Chevy C10
383, 700r4, 3.73's
A little rust never hurt anyone. I consider it weight reduction.
bamabaxter is offline   Reply With Quote
Old 05-01-2008, 07:15 PM   #2
Mister laugh
Re: Headlight Relay Upgrade
I agree, even on standard sealed beams it makes a huge difference. But when you upgrade further to H4's with a GOOD bulb wow what a difference you can get.
Mister laugh is offline   Reply With Quote
Old 05-01-2008, 08:02 PM   #3
71MUTT
Can't ReMember
71MUTT's Avatar
Give a poor old man a link...............................
Adversity doesn't test your character; it reveals it.
71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running )
71MUTT is offline   Reply With Quote
Old 05-01-2008, 08:55 PM   #4
Mister laugh
http://67-72chevytrucks.com/vboard/s...d.php?t=182351
link for you.
Old 05-01-2008, 08:59 PM   #5
muscletrucks
muscletrucks's Avatar
Ya happy now Mutt?
1972 GMC Sierra Grande 3/4 Ton 4x4
1970 Mercury Cougar XR7
1943 Farmall M
muscletrucks is offline   Reply With Quote
Old 05-01-2008, 09:08 PM   #6
manimal
manimal's Avatar
I wil see if I can locate the thread. But here is a run down...
Tools needs:test light,soldier iron/soldier(60-40),shrink tube,heat gun/lighter,wire cutters/strippers,(2)30amp Bosch style relays SPDT,female spade connectors,10g ring terminals,(2)inline fuse holders w/30amp fuses,small roll of 10g automotive grade primary red wire,14g balck primary wire for the ground,electrical tape and plastic wire loom. I may have frogotten something,but as you go you'll firgure out if you need something.
First off,DISCONNECT BATTERY,then unplug the headlight socket on the drivers side,turn on the lights and find the "LOW" beam wire with the test light, then hit the "HIGH BEAMS" and repeat. Mark each wire.
I strip back the factory wire wrapping about 12-18" BEFORE the driver side loght socket and expose the wires. Find the wires that you marked for the "LOW" and "HIGH" and cut them. Strip back the ends COMING FROM THE FIREWALL CONNECTOR,slide a piece of shrink tube onto each wire,then either crimp AND/OR soldier on a female spade connector. Then heat shrink the tube on the ends. That will plug into the #85 position on the relays.(mark your relays HIGH-LOW)
Now take and strip the other end of the wires you cut,slide a piece of shrink tube over and crimp AND/OR soldier on another female spade connector to those. Match the wire colors and plug into the #87 position of the relays.
Now take your 10g RED primary wire and run from the BATTERY + side terminal
across the radiator support to you relays. Instal a ring terminal on the battery end. On the relays,the position #30 is the power side. Take your inline fuse holders,install a female spade connector on ONE end and plug into relay(#30 position). Now strip back the other end of both AND the 10g RED wire from the battery and soldier all three wires together...DONT FORGET TO SLIDE ON SOME SHRINK TUBE. Now heat shrink the splice.
Now take the 14g BLACK primary wire(you'l need 2 pieces at least 8-10" long)and strip back both ends,one end gets a female spade,the other gets a ring terminal. This plugs into the #86 position on the relays and the ring terminals go to a GOOD ground.
And that should do it. Reconnect the battery,install the 10g RED wire to the + side terminal on the battery,and turn on the headlights and check. Good Luck.
I dont have a schematic drawn,but a few pics of the way I have done mine. Also I go to the wrecking yards and find the headlight harness out of another truck so I can position the relays where I want. I will cut the harness thats in the truck off at the drivers side connector then cut the "NEW" donor harness off back BEFORE the connector about 12-18", so I will have enough to play with.
If you pm me with your email I will send you pics of mine. Good Luck.
-Lance
If I forgot something,please someone chime in. Thanks
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-01-2008, 09:36 PM   #7
bamabaxter
bamabaxter's Avatar
Don't forget to put some kind pf circuit breaker between the relays and the battery. I got a little 30 amp circuit breaker from Advanced in the electrical section that will open and re shut itself if needed...no fuses required.
'72 Chevy C10
383, 700r4, 3.73's
Old 05-01-2008, 10:14 PM   #8
Riveted1
Tasty Cakes!
Riveted1's Avatar
If you don't feel like taking the time to do it all yourself and want it to look pretty, check this out. (Look in the lower left-hand corner)
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-01-2008, 10:20 PM   #9
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Well i put the same relay setup on my electric fans but with no breaker. Should i stop and get a breaker???
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-01-2008, 10:40 PM   #10
manimal
manimal's Avatar
Thank You, forgot to mention to install fuses or circuit breakers.
-Lance
-Lance
Old 05-01-2008, 10:42 PM   #11
manimal
manimal's Avatar
If done right,it will look VERY good. possibly even STOCK.
-Lance
-Lance
Old 05-01-2008, 11:21 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I k now the LMC kit that is linked up there has total crap relays. Knowing there commitment to quality (snicker) I would expect the plugs to be junk also.
Old 05-01-2008, 11:22 PM   #13
chrislehr
Engine n00b
chrislehr's Avatar
Tough to justify $40 shipped though. Any board vendors make one pre-made?
chrislehr is offline   Reply With Quote
Old 05-01-2008, 11:31 PM   #14
steelhorse
steelhorse's Avatar
I would be interested in it too.
steelhorse is offline   Reply With Quote
Old 05-01-2008, 11:32 PM   #15
bamabaxter
bamabaxter's Avatar
Jayherrell i'd recommend a breaker or at least fuses. I am putting the ford taurus fan on mine monday and i think everyone says at least a 30 amp fuse is required. most fans will blow a 20 amp. after seeing my friend's 240sx almost burn to the ground because his fans had no fuses and grounded out, i definitely try to do my electrical work with Murphy's Law in mind.
'72 Chevy C10
383, 700r4, 3.73's
Old 05-02-2008, 12:42 AM   #16
Riveted1
Tasty Cakes!
Riveted1's Avatar
Guess I'll find out tomorrow!
Old 05-02-2008, 12:48 AM   #17
Sinister
Between Trucks...
Sinister's Avatar
I have that LMC kit, works fine, looks clean, plug and play. I tried without luck to get some spare relays from the factory that made them, no luck, they're in Tawain and don't speak very good English...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-02-2008, 01:02 AM   #18
Riveted1
Tasty Cakes!
Riveted1's Avatar
Looks like you could just pick up some spare relays from Napa.
Old 05-02-2008, 01:06 AM   #19
Sinister
Between Trucks...
Sinister's Avatar
Good idea, just don't know if they're wired the same way...
Beat it to fit,
Old 05-02-2008, 01:50 AM   #20
Riveted1
Tasty Cakes!
Riveted1's Avatar
Should be... they're just simple SPDT relays I believe... will know more tomorrow when my kit shows up.
Old 05-02-2008, 02:09 AM   #21
Rollie396
someday it will be done!
Rollie396's Avatar
Just for the record,I'm completely illiterate when it comes to auto electric,but this is something you can do!
I did it on my '80 with stuff I either had or bought from napa.
P.S.I would have used shrink wrap on the yellow connections,but I didn't have large enough tubes at the time.
*edit*The single 10awg wire comes from the firewall bulkhead(on an 80,I believe 72 and earlier are on the core support).That wire runs through a 30amp breaker(if something goes wrong,the lights will flash on and off,unlike a fuse which will be a daaaarrrrkk ride).From there,I split it off into to bright and dim relays.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
Old 05-02-2008, 02:33 AM   #22
Longhorn Man
I used H.D. relays off a scrapped '96 P/30 step van. Got the plug with weather pack connections, and cut the pigtail off nice and long.
Now I just need to do the burb.
Old 05-02-2008, 03:16 PM   #23
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I like that idea! Do you have a picture?
Thanks,
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 05-02-2008, 10:20 PM   #24
manimal
manimal's Avatar
I am in the process of "making" my own set-up and reselling. But would be ALOT nicer than LMC's. Better Quality and probably a little more money.
-Lance
-Lance
Old 05-02-2008, 10:26 PM   #25
jayharrell
jayharrell's Avatar
Where did you get that junksion block longhorn??
i"ve hit every auto parts store in town and no one has one. I need one for my fan relay, and in the future will need the same block for the head light relays.
I just need to hit the man mall i guess and snatch one up.
00 S10 2.2 Vin5
