Old 06-29-2008, 06:42 PM   #51
Ilike 72"s
Re: Barn find resurrection
Originally Posted by 1967 C10 Dylan View Post
Nice wooden bumper you have there, that a custom touch?
I'm doing my part going green. Using natural resources.
Ilike 72"s is offline   Reply With Quote
Old 07-16-2008, 12:45 AM   #52
Ilike 72"s
Still chipping away. I would like it on the road by the end of July.I'm still painting piece by piece and installing it. I got most of the front clip on and saw that me and Bud Wiser got the strip on the cowl to big. I'll have to re do it. I found out the hard way new bolt clips on the inner fenders are the only way to go. Installed new black carpet and painted a tilt wheel silver. I installed a red dash pad but dont know if I like it. might go back to black. Installed Red and black hounds tooth bench seat. Seams to sit to high so I,m going to lower the rails.
Old 07-16-2008, 12:57 AM   #53
Ilike 72"s
more pictures. Can't decide if i'm going to paint the grill or leave it stock.
Old 07-16-2008, 01:01 AM   #54
CgSimms
CgSimms's Avatar
Are you really going to sell that truck? I think your crazy!
"TURNIN WRENCHES FOR FREEDOM"
SSGT USAF
72 GMC Short Bed EFI Vortec 383 Stroker
CgSimms is offline   Reply With Quote
Old 07-16-2008, 01:13 AM   #55
Ilike 72"s
Started on the bed. Went from a complete bed to small chunks in a hurry. Loaded it up and will haul it to the sand blaster tomorrow.
Old 07-16-2008, 01:16 AM   #56
Ilike 72"s
Crazy?? I don't think so. Maybe Stupid.
Old 07-16-2008, 06:41 AM   #57
Gray Ghost
Gray Ghost's Avatar
Originally Posted by chevychase View Post
The 882's are definitely a 350/400 head from the smog era (1974-80) and don't get too much love as a performance head. I'd use them on a cruiser if you didn't have to put any $ into them.
They get none from me...that casting is very prone to cracking. Now the block...that's a good one...hang on to it!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 07-16-2008, 10:36 AM   #58
Ilike 72"s
I would hang onto the block if I could. It was what I had at the time and this project needed it. Who ever ends up with this pickup will have a good 4 bolt block that they can install better heads if they want.
Old 07-16-2008, 12:08 PM   #59
Hart_Rod
Hart_Rod's Avatar
Great progress in such a short time!! I wish I worked at that rate, .
Hart_Rod is offline   Reply With Quote
Old 07-16-2008, 03:43 PM   #60
dan42
dan42's Avatar
Very cool build. I don't normally like stripes like that, but those look really nice. Just be careful of Bud Wiser, he's not your friend when it comes to painting!
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 07-16-2008, 04:20 PM   #61
Ilike 72"s
I have a bad habit of trying to make things to perfect. So I never get things done. I thought Bud Wiser would help things move along. It did help things move along. Now I need to repaint the cowl. As for useing strips, I hope I didn't screw up by making them to wide. ==Do you think I should run the stripe into the grill and paint it silver? How about Red? How about Black?? Or Origional?
Old 07-17-2008, 12:29 AM   #62
Ilike 72"s
Today I sent the bed parts off to be sandblasted. Tonight after work I straightened the grill. This has been very time consuming. So instead of polishing it out I decided to paint it black like the lower half of the pickup. I took the seat out and the tracks off so I can cut and lower them this week.
This I don't get--When I went to install the driveline, it was to long. Same one that came off. Would lowering it 3 inches cause this??
Old 07-20-2008, 07:00 PM   #63
Ilike 72"s
Still chipping away.Finished rough install of the front clip. I still need to adjust the gaps.
Straightened the grill. Taking to long to polish, so I painted it black with the insert painted silver.
Installed the grill. Installed the tilt and tranny linkage. Hooked up some wires, added fluids and fired it up.
Go@#^#n tranny cooler line wasn't tight at the radiator and sprayed oil all over. Cleaned up and tried again. Turned onto the street and had all the lug nuts fell off the front wheel. I don't know why it stayed on. I used the wrong nuts for that mag wheel. Found a pin hole in the radiator spraying water on me while I put the jack under it. Real nice day. Took the radiator out and called it a day!!
Old 07-20-2008, 07:38 PM   #64
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Damn thats a quick build... Looks pretty sweet...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-20-2008, 09:27 PM   #65
CgSimms
CgSimms's Avatar
I know you had some hesitations about painting the grill, I think it looks pretty damn good!
SSGT USAF
Old 07-20-2008, 09:44 PM   #66
Ilike 72"s
After I pounded out the crushed area on the drivers side--filed==sanded- filed--etc. It became clear to me it was getting painted. I lucked out that the hood stripe falls right into the grill insert corner. So I painted it silver to continue the silver flow of the hood stripe. Thanke for the compliment..
Old 07-20-2008, 11:34 PM   #67
Ilike 72"s
Just can't quit. Aligned the front clip gaps and installed the front bumper. I'm just winging it as I go. What do ya think so far.
Old 07-21-2008, 12:25 AM   #68
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
looks great.. nice paint job.....
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-21-2008, 01:59 PM   #69
Hair
So, you rebuilt that whole truck in like a week? I guess that's normal for you huh? I've been on my son's truck now for three months and it is still a pile of parts in the garage floor. I feel mentally retarded now. Thanks
Hair is offline   Reply With Quote
Old 07-21-2008, 08:07 PM   #70
Ilike 72"s
It's for sure been longer than a couple weeks, and no it's not normal for me. I don't know why but the timing was good and things seemed to fall in place. You can't be retarded if you like these trucks. The body style is great and their easy to work on. Dennis
Old 07-22-2008, 01:09 PM   #71
Ilike 72"s
Houston---we have a problem!! This will be a setback. Red oil on the floor. Damaged front seal in the trany.
Old 07-22-2008, 02:40 PM   #72
clay68c10
clay68c10's Avatar
That will keep you busy for a little while.
Awesome progress.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-22-2008, 08:29 PM   #73
RCbowtie69
RCbowtie69's Avatar
truck is looking good, keep the progress going & pictures coming, you're almost there, again looking good
RCbowtie69 is offline   Reply With Quote
Old 07-22-2008, 11:23 PM   #74
Ilike 72"s
I put on a set of 18 inch wheels after work. Ordered my trany parts today. Took the cowl off and am fixing the stripes as we speak. I'm waiting between clear coats. It's getting dark in my (paint booth) gravel driveway.
Old 07-25-2008, 02:00 AM   #75
Ilike 72"s
Fixed the cowl stripe to line up with the door and hood
Didn't like my new 18 inchwheels with 50 series tires, so I took them back and ask them to put 60 series on. They were real nice about it.TALLER SIDEWALLS. They had to order them.
Got my radiator back and installed it tonight.
Put the pickup up on the hoist so I can remove the tranny to replace the pump seals.
