Old 11-16-2008, 01:24 PM   #1
Jokers69
Active Member
Jokers69's Avatar
Header Solution
I was having problems tring to find full length headers with 1 3/4 primary tube that would not hang below the framerails with sbc. So I got with a local header shop and made a proto-type set and are now ready for production. We use heavy wall 14 gage steel tubing (.083) thick, 3/8" thick laser cut flanges, 14 gage tubing for our collectors and take great pride in our finish work. All of our headers are fully welded around each primary tube on both sides of the flange. This gives the header a more "finished" appearance, reduces areas for rust to start and adds superior strength. We hand finish each port and machine the face of the flange flat to fully seat to the head as well as insuring there is no reduction in flow. We offer all flange options but have found the ball/socket connection to be the best all-a-round connection. They offer a leak-free seal without the use of a gasket, allow for some movement and adjustability during the install and they are much more reliable than a flat flange. Primary tube sizes are available in 1 5/8" or 1 3/4", depending on the power/torque specs of the engine. They are $550.00 bare and $865.00 CHROMEX ceramic coating plus shipping. Here are some pictures and I will post more when I get them back from coating.
Last edited by Jokers69; 07-11-2010 at 03:13 PM. Reason: ceramic coating price increase
Jokers69 is offline   Reply With Quote
Old 11-16-2008, 01:30 PM   #2
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
More pictures
Old 11-16-2008, 05:48 PM   #3
c10crazy
Like a Rock!
c10crazy's Avatar
Re: Header Solution
Nice job! They look like they are modeled after Hedman. Will the finished product have the tubes dented in at the bolt locations or is this just because it's a prototype?
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 11-16-2008, 06:55 PM   #4
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
They will be clearenced on 1 3/4 and very little on 1 5/8
Old 11-16-2008, 10:57 PM   #5
Mudder
Mudder's Avatar
Re: Header Solution
How are they getting to the plugs?
Mudder is offline   Reply With Quote
Old 11-16-2008, 11:52 PM   #6
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
You have great plug access.You can run straight boot spark plug wires on all cylinders but #6 it requires a 90 degree boot.
Old 11-17-2008, 06:13 PM   #7
bigsnookmaster
bigsnookmaster's Avatar
Re: Header Solution
Those are very nice looking headers.I've built several sets over the years.They look like they're easy access to the plugs,and I like the 14gu. tubes,and the 3/8" flanges are nice. Seems to be a very fair price for the quality of the product.These headers coated will most likely last the life of the truck.
bigsnookmaster is offline   Reply With Quote
Old 11-17-2008, 06:43 PM   #8
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Thanks, They are very well built and no problems with them ever hitting the ground.
Old 11-17-2008, 06:46 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: Header Solution
Nice
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-19-2008, 11:53 PM   #10
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
These will not work on manual transmission with factory clutch linkage. The headers tubes will not fit around the clutch linkage.
Old 11-24-2008, 10:46 PM   #11
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Here they are coated.
Old 11-26-2008, 11:56 AM   #12
TCASON
TCASON's Avatar
Re: Header Solution
These are WICKED!! Can not wait tell my set go onto my truck
TCASON is offline   Reply With Quote
Old 11-28-2008, 02:14 PM   #13
larry may
Re: Header Solution
For these headers I ordered a set for my ole heap . Steve said be here in a week or so. Am looking forward to recieving these and getting them installed. I ordered the 1 3/4 coated headers.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 11-29-2008, 02:07 AM   #14
NWD02
Re: Header Solution
Awesome, very impressive.
NWD02 is offline   Reply With Quote
Old 12-01-2008, 03:14 PM   #15
larry may
Re: Header Solution
One more thing that makes this intriguing to me . Is that these are home grown. I paid ten years ago 610 dolars for Ceramic coated tuned Hookers for a 67 Camaro. The headers have been in side all their lives.In less that 4 years The Cramic has bubbled peeled, rust has come forward and ceramic is flaking off. I do not believe Steve will shanghi a customer with poop quality merchandise. Gotta try the homies one time.Oh I bought these Hookers from Summit!
Old 12-02-2008, 01:23 AM   #16
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Thanks Larry, all headers are top quality and all coating is done by Performance Coatings. I'm Running the same product on my truck.
Old 12-02-2008, 08:53 AM   #17
edin355
Re: Header Solution
Any idea on clearance problems for AC compressor? edin355
edin355 is offline   Reply With Quote
Old 12-02-2008, 12:42 PM   #18
larry may
Re: Header Solution
Edin 355 I 'm not running an AC unit. From the above pictures looks like they would work together. Not sure.
Old 12-02-2008, 06:32 PM   #19
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
I pretty sure they will have no problems with a\c compressor. But I also Don't have a/c in my truck. I will try to find out.
Old 12-02-2008, 07:12 PM   #20
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Header Solution
Very nice product, you will probably sell a boat load once the news is out...I see that on the pass side your plug wires run between the tubes on 6-8, and you say you use a 90 degree wire on 6. Do you think that 90 wires could be used on all cyl if you were to route the wires in the factory position, behind block, and up past motor mounts?
Also, is this an uncomplicated install, I have a/c, p/s, power disk. Thanks.
70k52wd is offline   Reply With Quote
Old 12-03-2008, 02:27 PM   #21
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
There should be no problems with running 90 boots with factory wire routing. It's a pretty easy install Drivers side goes in from the top and passengers goes in from the bottom. I'm running p/s and disc brakes With no booster (big cam) but they will not get in the way of the booster
Old 12-06-2008, 12:55 AM   #22
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The factory A/C lower compression bracket off the manifold will not work. We will try to get one made shortly (we got to get a compressor) Thanks Steve
Old 12-06-2008, 01:33 AM   #23
LuckyHenriksen
LuckyHenriksen's Avatar
Re: Header Solution
Hey if you were to make a set with Gen III flanges I would love one
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-06-2008, 02:11 AM   #24
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
I will see if that is possible.
Old 12-06-2008, 03:42 AM   #25
tll74
"Junkyard Dog"
tll74's Avatar
Re: Header Solution
VERY NICE! How about a set for a BB?
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
