Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-22-2008, 05:37 PM   #26
PA-IndianRider
PA-IndianRider's Avatar
Re: Ever wonder what that fiberglass front end saved you weight wise?
Originally Posted by Super73 View Post
John,
I'm going to fab up my own mounts. Most likely use some angle or flat steel on the bottom of the frame rail. Then some 3/4" ID round tube welded to it. That will allow me to put a 3/4 bolt or pin through it. I'll do the same on the fiberglass front end, then fiberglass the metal to the front end.
The bolt/pin will most likely have a set up like a tow hitch where you pull the lock out then the pins and can lift the whole front end off after tilting it.
If you want, it will most likely be pretty easy to do, I could probably slap a second set together after I do mine.
2 minute drawing..
Thanks 73..... as you can see in the above picture.... a previous owner started to make a tilt-mount for the front end.... I'll take some close up pictures of what's been done so far for you to see if the ideas you have for mounting your tilt front end will work or can be adapted to mine.... thanks again....
John aka "Milner"
PA-IndianRider - Pittsburgh, PA
70 Chevy C10 Stepside
"Gasser/Altered Drag Race Hot Rod"
Where were You in '62 ?
PA-IndianRider is offline   Reply With Quote
Old 11-10-2008, 11:20 PM   #27
bigoates
bigoates's Avatar
Hey does anyone have any pictures of a 73-87 tilt nose setup finished? looking for how well they fit to the doors etc..
Also, does anyone have the tilt setup that tilts down then slides back to the cowl?
Thanks,
Jon
bigoates is offline   Reply With Quote
Old 11-10-2008, 11:29 PM   #28
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The USBody pieces are made long on the ends so you can sand the finish to the best gap.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-10-2008, 11:39 PM   #29
bigoates
bigoates's Avatar
yeah I am familiar with that after helping with my friends car.
My main concern is the fit to the contour of the doors as well as how everyone is securing the rear lower portion of the fenders/wheelwells to stop them from vibrating and getting stress cracks
Old 11-10-2008, 11:49 PM   #30
Captkaos
Captkaos's Avatar
The lower section screws to the firewall, it lines up just like the original fender.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-19-2008, 06:28 PM   #31
scotts62
One day...
scotts62's Avatar
I have had mine for a while i like it a lot! makes the ngine very easy to work on!
Scott
93 crew cab build
Project 62
Old 11-19-2008, 06:51 PM   #32
bigoates
bigoates's Avatar
Hey all I picked up a sweet 1 piece tilt nose this weekend. It has a real trick set of hinges that extend forward about 18" so I can keep the fenders 1 piece.
Not sure of the weight of it yet but its def much more durable than most race weight noses.
Unfortunately its the newer 83+ nose and I was originally lookin for the older 73-79 nose for the truck.
[IMG][/IMG]
Old 11-19-2008, 07:11 PM   #33
scotts62
One day...
scotts62's Avatar
Sweet! is it steel or glass? Have any pics of the hinges?
Scott
93 crew cab build
Project 62
Old 11-20-2008, 04:27 AM   #34
Super73
Super73's Avatar
I clicked on the pic and it shows 3 picks in total and two of the hinge. But it keeps scroling so I can't get a great look at it.
Any chance you can mention where you got the hings and better pics?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-20-2008, 07:52 PM   #35
Captkaos
Captkaos's Avatar
Hope he doesn't mind... If so I will delete this..
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-20-2008, 09:02 PM   #36
Super73
Super73's Avatar
Who would mind? It's my thread, if anyone it would be me But I'm asking for even more pics
That looks like some aftermarket front suspension too.. Let's see more pics
Oh, do you know who makes that tilt hinge?
Old 11-20-2008, 10:17 PM   #37
bigoates
bigoates's Avatar
Hey guys, thanks for posting those pics better. I tried a few different ways and figured a slide show would be best.
The pics with the nose mounted to the truck is the truck it was on before I bought it. It was a 2wd k5 blazer pro street truck. The gentleman I bought it from wanted to put a steel nose on it to make it safer for when he drove it on the street with his wife and daughter.
As for the hinges I am not sure who makes them yet. He didn't know much about the origin either as they were on the truck when he purchased it last year.
Later on down the road I may be designing a newer beefier set of hinges (the grey pieces) because this nose is going on a tube chassis monster truck. Not sure the 1/4 brackets will be up for the punishment.
I have an appointment with a guy who builds fiberglass molds this weekend to see how uch it would cost to make me a mold of the nose so I can replace it easily if/when the truck is rolled over
It's a little easier to make a mold from a 1 piece because there are no seams to worry about which takes more labor to conceal I guess.
Oh and the front roll pan is actually steel that was nicel molded to the nose to give it a real clean look.
Old 11-21-2008, 02:03 AM   #38
Captkaos
Captkaos's Avatar
I was directing that at bigoates.
Some people put the pics in a slide show hoping to "hide" the direct links to the pics from others, and generally don't like them being exposed.
The suspension looks like a fatman Mustang II
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-21-2008, 02:38 AM   #39
Super73
Super73's Avatar
I gotcha.. Sorry bout that
Old 02-22-2018, 05:25 AM   #40
prostreet1967
prostreet1967's Avatar
what you end up getting ur truck down to super73
prostreet1967 is offline   Reply With Quote
Old 02-27-2018, 09:08 PM   #41
Super73
Super73's Avatar
I sold the front end to another member on the board. Last time I drove the truck it weighed 3,120 with me in it, full 16ga fuel cell and full 15lb N20 bottle.i weighed 202lbs at the time.
That is:
No inside of the bed
No front bumper
No hood
Inner fenders cut up some
CM back half and cage
Glide
Alum LS with Super Vic intake and N20 plate
Summit racing seats
Factory doors
Factory glass and regulators
Mustang 2 spindles
Wilwood brakes on all 4 corners
9" rear
Old 03-01-2018, 10:44 AM   #42
hotrod 80
mini truck racer
hotrod 80's Avatar
I don't know how tough it would be on the full size . but I'm about to take on Lexan swap in the wing and side windows and the factory tracks that still roll up and down.
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
