Old 11-20-2008, 09:54 AM   #1
Mrwlliam
72' Chevy question
Ive seen a few pics in my search yieldings, but my question isnt awnsered yet...
Can i simply add a notch and bag on the stock rear links and sit low.. Im not totaly beat up on laying out yet.. Just want to lay low for now.. Any input?
And I think the front is just a simple bolt on setup.. from S/D maybe?
Thanks Guys,
Will
Mrwlliam is offline   Reply With Quote
Old 11-20-2008, 01:00 PM   #2
Mrwlliam
Re: 72' Chevy question
Bump For lack of input..haha..
Old 11-20-2008, 02:07 PM   #3
mycool72
mycool72's Avatar
Yes, you can run the stock 2-link like I'm doing with a SD notch....adding blocks will give more drop if needed. Let me see if I can dig up a photo of mine on the two link without the notch....also keep in mind there are TONS of options on bagging, its all about preference and style..this site has a ton of info...so look around
mycool72 is offline   Reply With Quote
Old 11-20-2008, 02:09 PM   #4
mycool72
mycool72's Avatar
heres a quick shot of mine without the notch...adds a lot of drop..and def fun to play with
Old 11-20-2008, 02:58 PM   #5
Mrwlliam
wow, great..Thanks .. Are those airlift bags?
Old 11-20-2008, 04:19 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
to the board
You should check out the Texas CGITC in my sig
IMO, you dont gain much from a bolt in notch & you will have to cut a hole in your bed floor for the pumpkin to poke through
If I were you, I'd run some Slammed Specialties RE-6's in the rear with no notch, unless you dont mind having a hole in your bed
I dont like holes in my bed, so I didnt put in a notch when I bagged Sinister
And with Killer I did a frame Z & am raising the bed floor
Here is Sinister with no notch just bags
Ride height
Dumped
Also, blocks will only allow the axle to sit higher when the bags are at optimal height, not dump any lower
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-20-2008, 04:25 PM   #7
Mrwlliam
Thanks Bomb...
You mean that if i put the blocks on iit will not allow the truck to sit lower?
The only time i have used blocks was on the rear of a s10..
Thanks for the pics, and great truck!
Ps. Can you tell me about the front?
Old 11-20-2008, 07:37 PM   #8
Painter D
Painter D's Avatar
Here is a pic of how low you can get your truck without doing some form of major surgery. By major surgery I mean no Z'd frame, no step notch, no drop member, no hole cut out of the bed floor. This is a simple and easy setup using the factory trailing arms. Hope this helps.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 11-21-2008, 10:31 AM   #9
mycool72
mycool72's Avatar
Yes, mine are airlift, I like them a lot but i'm prob gonna switch to the Slam Specialties cause they are huge and ride smooth as hell....
Old 11-21-2008, 10:58 AM   #10
Shane
Shane's Avatar
Great looking truck 69chevyshort! What size wheels and tires you running?
Shane is offline   Reply With Quote
Old 11-21-2008, 12:31 PM   #11
Painter D
Painter D's Avatar
20x10 w/275-40 out back. 18x8 w 255/45 up front
Old 11-21-2008, 07:09 PM   #12
duceducenine
duceducenine's Avatar
heres mine with c notch and standard front set up
duceducenine is offline   Reply With Quote
Old 11-21-2008, 08:59 PM   #13
Mrwlliam
Thats the standard notch? not the step(larger) notch.. That color is georgous...love the truck brotha.. and thanks for the info..
Old 11-21-2008, 09:25 PM   #14
mycool72
mycool72's Avatar
If you're going to notch it, go with the step notch from SD...I think its only like 100.00, It would be a good investment, cause once you start going low, its only a matter of time before you want LOWER!!!
Old 11-22-2008, 10:57 AM   #15
Mrwlliam
Way cool bro.. thats proly hat i will end up doing
