Old 12-07-2008, 11:19 PM   #26
sweatmachine
Re: I think she **** the bed....
ok, I replaced the p/s pump today and found out that wasn't the problem!
There is a loose big metal ring around the main pulley area under the water pump. I'm not sure what it is, but it's a big metal ring that is loose, sitting on the pulley. Harmonic balancer ring?
I just bought a haynes manual but I'm not seeing it in the book.
It's sitting on the pulley and bouncing around loose when the truck is running, like a hoola hoop. What is it?!? I'll get a pic in the am when it's light out.
sweatmachine is offline   Reply With Quote
Old 12-08-2008, 12:19 AM   #27
67arch
WTB:Patience and Talent
67arch's Avatar
Harmonic balancer
69 shortwide
67arch is offline   Reply With Quote
Old 12-08-2008, 12:44 AM   #28
joe231
joe231's Avatar
yeah, balancer
i wouldn't run the engine until it is fixed, could cause some major problems...
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-08-2008, 08:22 AM   #29
SCOTI
SCOTI's Avatar
Yep.... Sounds like it tossed the harmonic balancer ring (it's steel held in place w/the molded rubber). Do not run the engine until getting this repaired. It's a common problem on high milage OE balancers. Pull it off & install a new one (new, not a different used one).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-08-2008, 11:12 AM   #30
sweatmachine
thanks guys, back to the auto parts store!!!
Old 12-08-2008, 11:59 AM   #31
Nolowrider
Nolowrider's Avatar
Replacing the harmonic balancer requires alittle effort. Not a hard job, but you have to remove a few things to get to it. Fan assy, probaly the water pump, crank pulley and space will be limited. But I am sure you can do it, just take your time. I suggest, while you are down there, go ahead and throw a new timing chain on her. With that many miles I am sure she would bennifit from a new chain. Oh yea, you are going to need a harmonic balancer puller to get the old one off. Most auto parts store will rent or loan you one. Good luck.
Nolowrider is offline   Reply With Quote
Old 12-08-2008, 03:04 PM   #32
sweatmachine
I'm pretty sure my uncle replaced the timing chain. It has a new cam in it and I think he put a new chain in with the new cam, but I'll check to be sure.
thanks again guys!
Old 12-08-2008, 08:47 PM   #33
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Dont forget about the balancer installion tool. Dont beat the balancer on!
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 02-07-2009, 03:56 AM   #34
sweatmachine
hey guys, I wanted to update this post, it ended up being the harmonic balancer, but I replaced both the balancer and the power steering pump. Now she runs smooth as glass!
Last edited by N2TRUX; 02-07-2009 at 07:18 PM. Reason: Only subscribing member may post items for sale!
Old 02-07-2009, 04:00 AM   #35
sweatmachine
btw, the Haynes manual is a giant piece of ****. Worthless.
Old 02-07-2009, 07:56 AM   #36
Ds86C10
2WD 4 Life
Ds86C10's Avatar
yup
Big D
1969 c10
1960 cadillac
1978 king cobra
Ds86C10 is offline   Reply With Quote
Old 02-07-2009, 03:30 PM   #37
MylilBowTie
Right turn Clyde
They make good coloring books.
Old 02-07-2009, 04:08 PM   #38
60ratrod
yes, i do
60ratrod's Avatar
i only use mine for torque specs and when i can't remember the firing order.
60ratrod is offline   Reply With Quote
Old 02-07-2009, 11:44 PM   #39
Skirkpat
Skirkpat's Avatar
buy a Chiltons, Haynes suck,
Skirkpat is offline   Reply With Quote
Old 02-08-2009, 12:06 AM   #40
lvschevytrucks
Unfinished Project Club
lvschevytrucks's Avatar
I thought I was the only one who hated haynes, nice to know Im not alone
Handle every Stressful situation like a dog.
If you can't eat it or play with it,
Pee on it and walk away.
1996 Dodge Intreped ES Nice car great on gas
1993 Jeep Cherokee.
Looking for a swb chevy 73-87
lvschevytrucks is offline   Reply With Quote
Old 02-08-2009, 01:28 AM   #41
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Nobody likes Haynes.
People buy em cause they are cheap and at autozone.
The one I got with my Volvo does seem pretty complete, I built a new ignition harness with it, but in general haynes manuals are for basic repairs, and I don't need a manual for basic repairs.
Napa has Chilton, and maybe pep boys?
The dampner must have been pretty wasted to make all of that noise.
heavychevy79 is offline   Reply With Quote
Old 02-08-2009, 01:36 PM   #42
sweatmachine
oh it was. The rubber part deteriorated to the point where the outer ring came off and was spinning around the inner part. I saved all the pieces.
