#26 |
Re: Tire / Lift size chart 67-72 (WILL IT FIT?)
bump, anyone
#27 |
thanks....
#28 |
I fit 42" swampers with only 6" lift. The way it was done was to relocate the front springs 4" forward by making a custom front spring perch, using 73+ springs and relocating the rear shackle hanger forward about 2 inches. I fabbed the shackle hanger out of 11 gauge plate and 1.75 tubing. Bushings are originally used in spring eyes. The hard part of the lift is trimming the fenders. Here's my hack / attempt.
hmm, maybe this should be in it's own post but I put it here to demonstrate that you don't have to get a nose bleed sized lift to run large tires. Lower center of gravity is safer too!!
1972 GMC Jimmy - 383SBC | TH350-NP203-NP205 | D60PL | 14FF Detroit | 42 TSL's | 4Xeyes | Heavy FOotE "Trail in. Trash out." Florida4x4 dot Com |
#29 |
I have a 71 K5 with a 4'' susp and 2'' body lift
My 36x15.50 Parnelli jones stuff just about right And the "look" is also pretty good, for ME some flex on a small ramp heres how it sits ![]()
71' K5 Blazer 6 in lift 36x14.50 Mud Grips Crate 350 with headers Needs a paint job! |
#30 |
Okay so we know what fits but when it doesn't how much cutting and where!
For example I'd like to run 38X12.5's on my 1st gen with just 6" of suspension lift. I plan on wheeling it as hard as I need to. Seems like I might get away with just a little bit of cutting but where and how much is the real question? The "chart" in the first reply in the thread would be good to see for all size tires by lift. Like: 38's w/4" = cut 1" off the front and XX off the rear 38's w/6" = cut 2" off the front andd xx off the rear I guess we'd need to know if we need to cut 2" off the front and 2" off the rear or the FRONT How high up do you need to trim the 2" up to as well. What about the inner fender... geez this is complicated! FYI: the guy 2 posts before this has a GREAT example of what to chop off!
72 GMC Jimmy, 350, sm465 np205 (getting a face lift) 64 Nova SS, 327 SC & gassed, TH350. (blowed it up) 84 HD FX frame,80 FL tins, evo with 85hp/90tq (wifes bike) 96 HD FatBoy evo with 102hp/100tq (mine!) KEEP NOTHING STOCK! Last edited by ericpost; 10-19-2008 at 11:36 AM. |
#31 |
BIG HEAD....Holy___, what is that thing in the pics? a truck?!?!
#32 |
#33 |
this may be the wrong thread to post this in but its semi-related so i will ask anyway
my 68 k10 has 31x10.5x15's on it and i was hoping to put 38's on the truck by the time next summer rolls around, i am pretty shure my truck has some form of lift in it, all i know for certain is that its not blocked and it doesnt have a body lift, i was told that the rear leaf pack isnt a halfton pack and looks to be 3/4 ton or larger and my front leaf packs are from a 79 blazer, i found that writen on the springs, would those leaf packs add a lift? and how long are the original 68 shackles? cause the ones i have look homemade? any help would be greatly apreciated thanks nate ![]() ![]() one of the front shackles is visible behind the homemade rockwell 221 fill tube ![]() this picture shows my rear leaf packs, ive never seen another 68k10 in person so these may be stock but a couple people i know said they are not factory for the truck, aslo can anyone tell me if this axle is anything special? its a 12 bolt 4.10 posi ![]()
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) Last edited by drivethechevy; 11-26-2008 at 12:58 AM. Reason: wrong picture code |
#34 |
my 68 fit my 33's with suuuuupppper tired springs i recently hacked my fenders myself, I've got plans for 38's in the near futere ; )
#35 |
[IMG]
![]() the rear looks like a dana.... here is my 68, but its a 3/4... looks totally different [IMG] ![]() mine is on 33's... very very minimal rubbing... not even a problem.. but they are bald... dodge cummins wheels, lol |
