18 Till I Die
Do 1987 Silverados have under-dash courtesy lights
I thought they did??? all I got is the interior dome light. Didnt they come with them?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home...
Sb 400 club
Re: Do 1987 Silvarados have under-dash courtesy lights
my 84 does... so I would think an 87 would too
1984 chevy c10, built 400sb,.(SOLD )77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
It'd be alot cooler if you did
I'll go check mine in a minute... it's 20 degrees outside!!
I like turtles...
my 79 does
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock ![]() Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. |
OK, just went out and looked and my 1987 Silverado has the under dash bulb right where they are on other trucks.
My 87 has 1 under the dash between the ash tray and glove box door, as well as the dome light.
Gene
#7 | |
18 Till I Die
Its -10 celcius here... Thanks guys. I wonder why you only have one between the ashtray and glovebox??. I thought they were one on each side. Is there one for the ashtray??
1977, in the center between the ashtray and glovebox.
18 Till I Die
Ahh yes found it bad bulb...I was looking more towart the outer sides. Thanks for the help
if you really want to brighten it up just stick an 1156 in it. Done that to all of mine, when i turn on the lights I wanna see!
Cheyenne Super
Re: Do 1987 Silverados have under-dash courtesy lights
All 73-87 Trucks have them, even the Custom Delux.
It's the dome light that only came on the Cheyenne/Scottsdale and Cheyenne Super/Silverado. It's not uncommon to find those lights removed and tangled up under the dash somewhere, don't ask me why. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Ditto on what heavychevy79 said. All of them got the underdash light, most ended up twisted and pointing toward the rear of the dash. I would guess it was from kids kicking around under the dash
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
My dome light burned up a few weeks ago and I had zero light but I completely forgot about the floor light. Guess I got a bad bulb to replace ?
1977 GMC Sierra Grande |
anybody happen to know the size of the bulb?
"All Throttle No Bottle" 1984 C10 Stepper
#15 |
18 Till I Die
I took it out and went to match one up. its a single point twist in. Dont remember the number
#16 |
alright ill look around I never realized there was even one there until i looked and the bulb is gone haha thanks anyways
#17 | |
For the ashtray, there is a fiber optic cable that runs from the upper RH corner of the gage cluster (which is where the bulb is) down to the top of the ashtray housing. My '87 also has one under dash courtesty light between the ash tray and glove box. I'll stick an 1156 in it when I get home! ![]() K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#18 |
mine does but i need to get a hole new cab light mine melted
#19 |
Just fyi, the under dash courtesy light is a 1003 bulb and the dome light is a 1004.
#20 |
![]() Join Date: Oct 2014
I know this is an old post that got pushed to the top. I thought I would add, that you could get the set of courtesy lights from LMC and add to the one under the dash. After splicing in the wiring to the existing light, I placed the new lights at each end of the dash. All 3 bulbs were replaced with LED Bulbs. It really added a lot of light, especially at night.
https://www.lmctruck.com/1973-87-che...tesy-light-kit
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#21 |
I be leave this option started in 83 if you want it. You ordered on your truck. In most cases the plugin will be there in the harness to add the option. GM was good for that.
But the option was more on high end Blazer/Jimmy and Chevy/GMC Suburbans
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
#22 |
My 84 Sierra didn't come with a dome light from the factory, only one under dash courtesy light, that doesn't work, so I bought an LED house light, and stuck it to the inside of the roof with the double stick tape it comes with. It's adjustable from light light to blinding.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
