Old 03-29-2009, 12:26 PM   #1
pumpkin
pumpkin's Avatar
Exhaust fumes in the truck
I was just wondering if anyone has problems with getting exhaust fumes in the truck at any time. Top on,, top off,, back window open? And where does your exhaust exit, if you do have exhaust getting in? I'm am tying to figure out where to put my tailpipes. I originally had it coming out the side just in front of the rear tires, and had no problem ever, but seem to remember on my other Blazer, at times there was fumes getting in. Its tail pipes where out the back.
pumpkin is offline   Reply With Quote
Old 03-29-2009, 01:02 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Exhaust fumes in the truck
If you route the exhaust out the side behind the rear wheels, you'll get less fumes inside the truck. You may also want to check the seals around tailgate and rear hatch.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-29-2009, 02:42 PM   #3
RED72blazer
urban fourwheelin
RED72blazer's Avatar
ditto.
Mine originally came out the back. the fumes where horrible. When I replaced it I went out the side, problem solved.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 03-29-2009, 07:26 PM   #4
vtblazer
vtblazer's Avatar
Best case scenario.
vtblazer is offline   Reply With Quote
Old 03-29-2009, 09:20 PM   #5
Mike C
Mike C's Avatar
MIne look like VTBlazers as well. The 45 degree angle has little effect on flow, but gets it out the side. You NEVER want a straight back exhaust on a 4x4 anyhow. When you get stuck and have to move forwards and backwards, you end up packing the exhuast full of mud and water!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-29-2009, 10:40 PM   #6
pumpkin
pumpkin's Avatar
So,,,, those people that do have the tailpipes out the side behind the tires,,,,, do you ever get exhaust fumes in the truck?
Old 03-31-2009, 05:58 AM   #7
vtblazer
vtblazer's Avatar
Wouldn't go so far as to say you'll never get any exhaust smell running the pipes out the rear/side but it seems to work the best.
Having all the rubber seals in place around the hatch & tail-gate also makes a big difference.
Old 03-31-2009, 08:57 AM   #8
pumpkin
pumpkin's Avatar
Thats sorta, what I remember. I think I'll just put it out the side in front of the rear tires. I know that way, there is no exhaust in the truck ever. Thanks for the input.
Old 03-31-2009, 10:02 AM   #9
Burt4x4
Burt4x4's Avatar
yup, going straight out the back is the fumiest location
I don't run a hardtop anymore and mostly the soft top stays down. BUTT if I have the soft top up and the back window removed/open peeeeeee-you
If I remove all the windows and run safari style then I do not smell the fumes and of coarse I don't smell anything full-vert
So for me...I just don't run it with only the back window open and I'm fine..no smell
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
