Old 05-14-2009, 12:12 AM   #26
texastrendz
Re: Air bag ?
agreed with xxl, keep it safe on the roads, foolish in the driveway.
texastrendz is offline   Reply With Quote
Old 05-14-2009, 12:15 AM   #27
project 67 sub
project 67 sub's Avatar
Re: Air bag ?
Texastrendz, yah i know what you mean about talking crap to people on forums, its pointless and does nothing but make yourself look bad. and their is deffinately alot of helpful people here that have helped me as well, and i appreciate every bit of info that i get here, its a great forum to be on. question: you say you are running the re7's(200 psi bags), but than you also say you turn it up to 400 psi to play, isnt that pushing the limits of the bags 2x's their intended max pressure?
BigShoe24, yah i was planning on boxing the frame anyways even if i dont hop it or anything.
yah i dont plan on driving it foolishly on the road, i like being a safe driver, it would just be for clownin in parking lots and at friends houses
p.s. once again guys thanks for all the help
project 67 sub is offline   Reply With Quote
Old 05-14-2009, 12:15 AM   #28
Twisted Minis
Twisted Minis's Avatar
Re: Air bag ?
I am not sure what DOT line is rated at, but I think it can handle 300 PSI. I would look at the line you have to be sure, some are different by brand. Hydraulic line is rated at several thousand PSI if I remember right, so that will be fail proof for you.
As far as the bag goes, I have never used the Airlift bags, but I feel Slam bags ride too stiff, especially the higher PSI rated ones. I've used them, and that's just my opinion. It's still a great bag, just too stiff for me. I prefer to use Contitech 4-ply bags. They are in the middle of the price range, and are a 450 PSI bag. They can be had from 1/2" single port to 3/4" dual port I believe.
I use them on the front of anything with a small block or larger up front just for a good ride. Minitrucks do alright with the 2-ply version though, as long as they still have a 4-cylinder.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 05-14-2009, 12:22 AM   #29
project 67 sub
Re: Air bag ?
Twisted Minis, i dont have any lines or bags or anything on it yet for that matter, im just trying to work things out in my head now so i know what im going to do when i finally get to that point.
Old 05-14-2009, 12:37 AM   #30
texastrendz
Re: Air bag ?
i went with the slam bag, the way it is built is a good design, when you tighten the mounting bolts you are actually cinching the bag together. this is why you do not want to inflate a slam bag unbolted. just my opinion. i feel perfectly safe doing what i am doing with the slam bags, others may say diffrent. they do ride stiff, design and construction. you really need to see some cut aways before you buy air bags. i liked the slam design, firestone is nice to. never messed with the conitech or however you spell it.
Old 05-14-2009, 12:37 AM   #31
Twisted Minis
Re: Air bag ?
If price is a factor, the hydraulic lines will cost you around $30-50 each depending on size and length. Last ones I got where 1/2".
Old 05-14-2009, 12:46 AM   #32
project 67 sub
Re: Air bag ?
yah i like the fact that the slams have an internal bumpstop in them and that is what i will end up running on my burb.
Twisted Minis, how much does the 1/2" hydraulic line usually run per foot?
Old 05-14-2009, 12:49 AM   #33
Twisted Minis
Re: Air bag ?
It's not that much per foot, less than a dollar. The expensive part is the swivel fittings and labor building the lines.
Old 05-14-2009, 12:57 AM   #34
project 67 sub
Re: Air bag ?
oh ok thanks. what would be about the average cost for the service of building the lines long enough for a burb to run the lines from the front of each bag, to the back about right in front of the rear axle. and then from each rear bag to possibly a nitrogen tank and 8 valves? not installed as i will do that part, but just building the lines.
Old 05-14-2009, 01:34 AM   #35
Twisted Minis
Re: Air bag ?
Roughly $30-50. I pay about $25 for the fittings and labor, then just the line by the foot.
Old 05-14-2009, 01:49 AM   #36
project 67 sub
Re: Air bag ?
ok thanks bro.
Old 05-14-2009, 10:17 AM   #37
fastbagged68
fastbagged68's Avatar
Re: Air bag ?
Slams all the way. They are the originator on hopping trucks on air. My buddy ran 180psi, 1/2 Parkers and his 65 would come off the ground. You might look at running 12 valves, 4 T in to your exhaust that are smaller so you can adjust it when you want to drive it.
And yes your truck will be destroyed....Fast if you are running big valves and lots of pressure.
fastbagged68 is offline   Reply With Quote
Old 05-14-2009, 12:20 PM   #38
fixit-p
fixit-p's Avatar
Re: Air bag ?
Originally Posted by texastrendz View Post
i used 3/8 hydraulic hose with jic fittings on everything. if i were to do it again i would build my system with parker push lock rubber hose, not hard line dot stuff. the rubber parker push lock stuff is awesome. rated at 350 psi with a 4 time safety factor. all you have to do is push the stuff on to the barbs, no clamps. no push lock fittings, just sounds simple, and the stuff is cheap and flexible.
I think the reason you haven't had any issues is because of the way you plumbed it. I use both push loc and hyd hose on a daily basis the push loc has a 4:1 safety factor just like hyd hose but is not recomended for pressure surge applications it has 1 textile or fiber braid as opposed to hyd hose which has multiple steel braids. I think if the crimped hyd hoses were replaced with just push loc you would have problems from pressure spikes which happen so fast you cant see on a typ. gauge.
fixit-p is offline   Reply With Quote
Old 05-14-2009, 02:15 PM   #39
project 67 sub
Re: Air bag ?
yah ive always liked slams even though ive never used them yet. if i was going to run alot of pressure it wouldnt be an all the time thing, just a once in a while thing cuz i know running high psi with large valves will do some damage if ran that way all the time(and i'd deffinately box the frame). and just curious but how would i go about running a 12 valve system, would it be 2 fills and 1 dump per bag, or 1 fill and 2 dumps per bag?
Old 05-16-2009, 11:57 AM   #40
fastbagged68
Re: Air bag ?
I ran 1lift and two exhausts. I T the 3 valves with a machined block. Whats your email, I can email you pics. Idont have a program to resize my pics.
