Old 07-06-2009, 01:43 PM   #1
DC_Jimmy
Leveling?
So I just replaced the front lift springs on my '71 Jimmy with stock springs. Back has 4" blocks which I intended to remove...until I saw the vehicle stance as is. Nice, aggressive posture. On evenly worn out 33s, front roofline comes in at 6'3", rear roofline at 6'5". So do I really want the rear down at 6'1" or ideally at 6'3"? Is 2" of rear spring sag normal? Thinking of replacing the 4" blocks with 2" blocks. Thoughts on ideal relative height front vs rear?
DC_Jimmy is offline   Reply With Quote
Old 07-06-2009, 04:05 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Leveling?
Ya got pictures.
A lot of guys run 1-2" of lift to compensate for the "saggy-butt" look.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-06-2009, 04:43 PM   #3
teamradrz1
teamradrz1's Avatar
Re: Leveling?
I think it's really up to you how do you like your vehicle? Everyone has an opinion and lots are different do what makes you happy and what you like to look at. I did some things to my truck that I like and not to many do, like my stereo install. Sometimes I like to hear people's opinions and sometimes I just do it my way.
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 07-06-2009, 05:28 PM   #4
capev86
Re: Leveling?
use 3/4 ton rear coils in back. i will sell mine (eventually) when i upgrade to the HD option rear coils on my 72 suburban 3/4 ton. the springs fit. my dad had 3/4 ton springs on his 72 1/2 ton suburban and it sat like a hot rod (tail high) and ithe aux springs never engaged after the swap when he hitched up the trailer. my truck has 1" rake front to back, measured to the edge of the fender lip above the wheel. it looks level, but i want a bit more substantial rake and extra capacity for towing heavy trailers! oh....standard duty 3/4 ton rear springs were optional on 1/2 ton suburbans....a sort of trailering package setup....
capev86 is offline   Reply With Quote
Old 07-06-2009, 06:40 PM   #5
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Re: Leveling?
are you talking about a 2wd?
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 07-06-2009, 08:30 PM   #6
capev86
Re: Leveling?
YES!!! 4x4's didn't have coil springs!
Old 07-06-2009, 08:51 PM   #7
RED72blazer
urban fourwheelin
Re: Leveling?
I know. but you wrote this first.
It had me confused....Since we are talking about a 4wd.... I wasn't sure if you were talking about a leaf sprung 2wd or a leaf sprung rear with overloads or what
Old 07-06-2009, 09:12 PM   #8
capev86
Re: Leveling?
my bad...i was thinking 2wd.....forget most blazers are 4 wheel drive. i wasn't firing on all 8 cylinders and totally missed the spacer blocks originally mentioned....leaf spring only....duh!
carry on and forget i was ever here.......
Old 07-06-2009, 09:17 PM   #9
RED72blazer
urban fourwheelin
Re: Leveling?
hahaha
well, at least I'm not the crazy one.
Old 07-06-2009, 09:20 PM   #10
capev86
Re: Leveling?
yeah....i have my moments.....
but now that i am on the right page....same idea applies.....use an add a leaf kit or preferably put in 3/4 ton spring packs. 4x4's definitely like to sit high in the front!
level
