Old 07-09-2009, 07:02 PM   #1
timzrides
timzrides's Avatar
One Piece Drive Shaft what options?
I bought a ECE drop trailing arm crossmember from a member. what is my best option to converting to a one piece drive shaft. my truck that i'm building is a 70 swb with 71 running gear and will be bagged. i'll most likely be using a 350 or 700r4. thanks
timzrides is offline   Reply With Quote
Old 07-09-2009, 07:43 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: One Piece Drive Shaft what options?
If your 350 is mounted in the front frame holes on proper small block mount stands and you run a 700 R4, you can get a driveshaft out of an 88-98 regular cab Short bed V8 automatic truck.
I've done this twice myself. Only caveat is that you will need a conversion u joint on the rear since the early model 12 bolt rearend you have uses a larger series of u joint than the later truck did. The conversion u joint is available at any O Reilly or Autozone store.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-09-2009, 08:07 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Being that you are going with bags, you are better off keeping the 2 piece shaft. With a single shaft anf adjustable suspention, you are very likely to have the shaft hitting the crossmember.
Old 07-09-2009, 08:58 PM   #4
timzrides
timzrides's Avatar
for the two piece, what about the drive shaft attachment on the new ece crossmember?
Old 07-09-2009, 09:25 PM   #5
Longhorn Man
never seen one.
Does this piece have a larger opening for a one piece shaft?
Old 07-11-2009, 07:36 PM   #6
timzrides
timzrides's Avatar
any ideas where to get a one piece driveshaft for a shortbed?
Old 07-11-2009, 07:48 PM   #7
CaptMadDog
i had a shop chop the ends off my two peice and make me a one peice i just specified the lenth i wanted they hacked and slashed one out for me. it was about 200 but its beafy as heck.
hope this helps
josh
My build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=348729
CaptMadDog is offline   Reply With Quote
Old 07-11-2009, 07:51 PM   #8
BP68
BP68's Avatar
I am running a 700R4 on my 68 swb. I took a 72 longbed one piece shaft and the correct yoke for the 700R4 and had a driveshaft shop shorten the saft and istall the yolk. The stock rear joint fit the rearend perfect.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 07-11-2009, 08:50 PM   #9
big_al_71
big_al_71's Avatar
I had a one piece built by a local driveline place new joints and tranny yoke for $225.00 zero vibration it has been there for almost a year..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
