Old 08-11-2009, 11:12 AM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Help on ID'ing a few things on a 5.3L
Can anyone help me identify a few things on my 2006 5.3L?
#1 - Sensor on front of intake, right behind the TB:
#2 - The hose that runs from the sensor in #1 runs to the back of the engine on the drivers side and was disconnected from something. What is the hose suppose to plug in to? (end of hose is #1)
#3 - The vent hose on the transmission splits and runs toward the engine and ends with a check valve. the other end was loose. Any idea where that end with the "?" goes?
#4 - This sensor above the starter:
#5 - This module, looks as though it was on the inside of the cab:
#6 - This gizmo was tied around the negative battery cable near the battery terminal end, and ran straight to the PCM:
Thanks in advance for any help ID'ing this stuff!!!!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-11-2009, 11:37 AM   #2
fxdxharley
Just a nother gear head
fxdxharley's Avatar
Re: Help on ID'ing a few things on a 5.3L
I just had mine all apart. would have to look at the manual for exact names. Do you have a manual? if not go get one. mine was a life saver.
the hose in pic 2 conects to the port withe the 2 white dots just to the right of your hand.
the sensor above the starter is the crank position sensor.
Thats all i can id right now with out going out and looking at mine and fliping threw the manual.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 08-11-2009, 11:48 AM   #3
glock35ipsc
OK, thanks. I though I disconnected wires from both of those, so I'll have to look again tonight.
No one makes a manual for a 5.3 Vortec in an 85 GMC.
Bob
Old 08-11-2009, 11:50 AM   #4
fxdxharley
fxdxharley's Avatar
I will go out and check my truck and get back to ya. just to be sure.
2013 HD FLHX
2000 harley fxdx
Old 08-11-2009, 12:03 PM   #5
fxdxharley
fxdxharley's Avatar
sorry man i was wrong. the tube is part of the evap system and connects to a metal tube that runs along with the fuel lines to the tank. so the sensor the tube goes to is some sort of vacum valve.
I took a bunch of pics with my digital during the taredown just incase i forgot where stuff went and labeled every plug i un did even tho most will only go in one place.
2013 HD FLHX
2000 harley fxdx
Old 08-11-2009, 12:07 PM   #6
glock35ipsc
Cool, thanks! I'm doing away with the EVAP, so I can probably just pull the sensor out and make a dummy plug for that hole in the manifold then.
Thanks again!
Bob
Old 08-11-2009, 12:49 PM   #7
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
1 Is the Evap system purge solenoid.
2 Is the purge hose. It goes back to the fuel system, the purge solenoid pulls fumes through it and burns them instead of venting them into the atmosphere.
3 Just hangs down, if the trans overheats and blows off fluid it will go under the truck instead of all over everything if it came out of the top vent
4 Is the crank sensor like already mentioned.
5 Is the Body control module (BCM) mostly controls interior features like door locks and such.
6 Is the Generator battery comtrol module. Basically it uses amperage draw, battery temp. etc. to regulate the battery charge voltage.
If there's anything you need more info. on let me know. I have the world of GM at my fingertips... for now
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 08-11-2009, 01:00 PM   #8
glock35ipsc
Beauty, thanks Mike!! Is #6 necessary, or can I have to removed too? I've never seen one before. The battery on the 85 is on the passenger side, but I might move it to the drivers side to keep hooking up the 5.3 harness easier. But if I left it on the pass side I'd have to extend all the wires for the #6 thingy.
Bob
Old 08-11-2009, 01:24 PM   #9
BACKYARD88
BACKYARD88's Avatar
You should be able to have it removed. It defaults to 13.8v if it's unplugged or has a problem. As long as someone can program the PCM to not set the code for it all should be good.
-Mike Owen-
Old 08-11-2009, 02:01 PM   #10
glock35ipsc
Awesome, thank you for your help!!
Bob
Old 08-11-2009, 02:16 PM   #11
BACKYARD88
BACKYARD88's Avatar
Glad I could be of service
-Mike Owen-
Old 08-11-2009, 02:51 PM   #12
fxdxharley
fxdxharley's Avatar
Well i guess you better get started then
get one for the yr of 5.3
2013 HD FLHX
2000 harley fxdx
