09-09-2009, 07:30 AM | #1 |
I've got Loose Balls!.....(rear view mirror)
So I bought a reproduction inside rearview mirror for my 'Burb.
Even though it's a '72, I went with the '69-'70 style so that I could bolt it to the windshield frame instead of messing around with the glue that never seems to hold. The mirror looks great, but every time I drive the mirror slips out of adjustment and tilts down. At first, I thought it was the upper ball socket (the one you can adjust tension on inside the mirror mount), but it's actually the one inside the mirror head itself. As far as I know it's not adjustable for tension.....or is it? Is there a way to take apart the mirror somehow to tighten this up, or should I just try some kind of loctite to try to clog up the ball socket and make it hold it's position better???? -G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
09-09-2009, 07:43 AM | #2 |
67-72 parts collector,…
Re: I've got Loose Balls!.....(rear view mirror)
I'd like to know also. I have the exact same problem with my repop mirror.
09-09-2009, 10:52 AM | #3 |
Why not return it and tell them to send you on that's not a piece of...
09-09-2009, 10:56 AM | #4 | |
The unit overall is nice. No spots all over the mirror like my old one.... Just need a way to tighten up that lower "ball". I suppose I could come up with some sort of set-screw retrofit if needed, but I was hoping someone here had a clever BTDT solution... -G
09-09-2009, 11:00 AM | #5 |
Mine came from Classic Parts. I may have to give them a call.
09-09-2009, 11:07 AM | #6 |
I'M TRUCK CRAZY!
Not trying to highjack... but do you have pics of your burb?
Oh, and I would also like to know the answer to this. Last edited by LOW DOUGH; 09-09-2009 at 11:09 AM. |
09-09-2009, 11:11 AM | #7 | |
The Older Generation
A solution I have used on a couple of old mirrors was to use a small, sharp (read pinpoint) center punch and punch a couple of places on the ball to tighten it up in the socket. You have to rotate the mirror to punch it so that the dimples will be inside the socket when the mirror is installed and adjusted. Don't get carried away with the punch, just do a couple of small ones and try it. It doesn't take much. You can always get more aggressive if the first time doesn't do it..... If you can't get it situated right to get it punched try having someone hold it while you punch it. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-09-2009 at 11:14 AM. |
09-09-2009, 02:57 PM | #8 |
Tot Roddin'
Throw your in the Blazer this weekend...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 09-09-2009 at 02:57 PM. |
09-10-2009, 12:13 AM | #9 |
70 Chevrolet=Obsession
Funny... I bought a repop mirror from Classic Parts and the ball in the mirror is just fine but the joint with the setscrew seems to loosen up all the time no matter how hard I tighten the setscrew. Oh well, I guess we all have our problems.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
09-10-2009, 01:05 AM | #10 | |
09-10-2009, 05:24 PM | #11 | |
09-27-2011, 10:34 PM | #12 |
(old thread, back from the dead)
09-27-2011, 11:08 PM | #13 |
Fabricate till you "puke"
I tryed that on my balls....the wifey said it tightened them up a tad, but the girlfreind still says they are loose ass hell crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
09-28-2011, 12:10 AM | #14 |
100%
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
09-28-2011, 12:43 AM | #15 |
Maybe you should show it some kegel exercises Just kidding
72 C20 Longbed 05 1500 Z71 |
09-28-2011, 01:25 AM | #16 |
Well, we all new that it ....would go a tad crooked, I dont think the kegel exrecices will help my balls tho(the locktite seemed to work) CrazyL, 54 yrs old , but goin on 18
09-28-2011, 10:01 AM | #17 |
I would definitely be returning the mirror if it were bought locally but after paying for the return shipping cost it's not worth it to me. At this point a remedy to get the mirror just a little tighter is the best option. BTW, the mirror looks great and correct, just loose.
09-28-2011, 10:11 AM | #18 |
I purchased another repop mirror recently,... hoping the first one I got was a bad one.
Nope. This one is just as loose. Really s#cks. I'm looking for answers also.
09-28-2011, 10:19 AM | #19 |
20' Daredevil (Ret)
Mine were once loose also.... no longer an issue, the wife now keeps them safe in a jar.
Dunno where she hides the jar, though......
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-28-2011, 11:05 AM | #20 | |
Location: North Cal and no Sac or Bay area is not NORTH
Never argue with an idiot, they will bring you to their level and beat you with experience.. |
09-28-2011, 11:47 AM | #21 |
If you will remove the screw from the mirror head they are a little triangle pc. made out of spring steel were the screw would go through the mirror You can replace this only and the the mirror head will tighten up.
09-28-2011, 06:11 PM | #22 |
I hate to be the redneck, but I too bought an aftermarket mirror, I wedged a couple of tooth picks in mine to get the mirror tighter. I hated the drooping and sagging as well. Mine still shakes some when I'm going 70 down the highway but at least I can see out of it.
Keith |
09-28-2011, 08:19 PM | #23 |
Here is the part http://www.classicparts.com/1960-71-...ctinfo/57-411/
09-28-2011, 11:05 PM | #24 | |
09-30-2011, 06:00 PM | #25 |
Update: I contacted Classic Parts to return my mirror. It was useless and I'm not into fixing new parts. Anyway, they were great to deal with. They shipped me another mirror that they pulled off the shelf and tested before shipping... while I was on the phone with them. They are also sending a return label for the old one (and the new one too if there is an issue).
Great customer service and hopefully it works out, I did purchase the mirror because I need one and they look very nice. |
