Old 09-09-2009, 07:30 AM   #1
-Greg72
-Greg72's Avatar
Talking I've got Loose Balls!.....(rear view mirror)
So I bought a reproduction inside rearview mirror for my 'Burb.
Even though it's a '72, I went with the '69-'70 style so that I could bolt it to the windshield frame instead of messing around with the glue that never seems to hold.
The mirror looks great, but every time I drive the mirror slips out of adjustment and tilts down. At first, I thought it was the upper ball socket (the one you can adjust tension on inside the mirror mount), but it's actually the one inside the mirror head itself. As far as I know it's not adjustable for tension.....or is it?
Is there a way to take apart the mirror somehow to tighten this up, or should I just try some kind of loctite to try to clog up the ball socket and make it hold it's position better????
-G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s
Find me on INSTAGRAM @MIGHTASWELLK5
'72 K5 - Greg's "Might As Well™" Build
-Greg72 is offline   Reply With Quote
Old 09-09-2009, 07:43 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: I've got Loose Balls!.....(rear view mirror)
I'd like to know also. I have the exact same problem with my repop mirror.
Keith
Convert to disc brakes.
Old 09-09-2009, 10:52 AM   #3
69GMCLonghorn
69GMCLonghorn's Avatar
Why not return it and tell them to send you on that's not a piece of...
69GMCLonghorn is offline   Reply With Quote
Old 09-09-2009, 10:56 AM   #4
-Greg72
-Greg72's Avatar
The unit overall is nice. No spots all over the mirror like my old one....
Just need a way to tighten up that lower "ball". I suppose I could come up with some sort of set-screw retrofit if needed, but I was hoping someone here had a clever BTDT solution...
-G
Old 09-09-2009, 11:00 AM   #5
lolife99
lolife99's Avatar
Mine came from Classic Parts. I may have to give them a call.
Keith
Old 09-09-2009, 11:07 AM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Not trying to highjack... but do you have pics of your burb?
Oh, and I would also like to know the answer to this.
LOW DOUGH is offline   Reply With Quote
Old 09-09-2009, 11:11 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
What 69GMCLonghorn suggests is definitely an option and if enough people did that they might get the message and fix the problem.
A solution I have used on a couple of old mirrors was to use a small, sharp (read pinpoint) center punch and punch a couple of places on the ball to tighten it up in the socket. You have to rotate the mirror to punch it so that the dimples will be inside the socket when the mirror is installed and adjusted. Don't get carried away with the punch, just do a couple of small ones and try it. It doesn't take much. You can always get more aggressive if the first time doesn't do it..... If you can't get it situated right to get it punched try having someone hold it while you punch it.
LockDoc
Leon
Old 09-09-2009, 02:57 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Throw your in the Blazer this weekend...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-10-2009, 12:13 AM   #9
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Funny... I bought a repop mirror from Classic Parts and the ball in the mirror is just fine but the joint with the setscrew seems to loosen up all the time no matter how hard I tighten the setscrew. Oh well, I guess we all have our problems.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 09-10-2009, 01:05 AM   #10
jaros44sr
jaros44sr's Avatar
LockDoc
Very good answer...that should work
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-10-2009, 05:24 PM   #11
oldcarfart
-G
I would try some green (wicking) loctite.
oldcarfart is offline   Reply With Quote
Old 09-27-2011, 10:34 PM   #12
-sean-
Wink (old thread, back from the dead)
anyone try this?
I just received my mirror from Classic Parts and it is very loose... to the point that shutting the door to hard will cause it to move in the ball joint.
-sean- is offline   Reply With Quote
Old 09-27-2011, 11:08 PM   #13
crazy longhorn
Fabricate till you "puke"
I tryed that on my balls....the wifey said it tightened them up a tad, but the girlfreind still says they are loose ass hell crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-28-2011, 12:10 AM   #14
70cst
70cst's Avatar
What 69GMCLonghorn suggests is definitely an option and if enough people did that they might get the message and fix the problem. LockDoc
100%
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-28-2011, 12:43 AM   #15
sleepertruck72
sleepertruck72's Avatar
Maybe you should show it some kegel exercises Just kidding
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 09-28-2011, 01:25 AM   #16
crazy longhorn
Well, we all new that it ....would go a tad crooked, I dont think the kegel exrecices will help my balls tho(the locktite seemed to work) CrazyL, 54 yrs old , but goin on 18
Old 09-28-2011, 10:01 AM   #17
-sean-
I would definitely be returning the mirror if it were bought locally but after paying for the return shipping cost it's not worth it to me. At this point a remedy to get the mirror just a little tighter is the best option. BTW, the mirror looks great and correct, just loose.
Old 09-28-2011, 10:11 AM   #18
lolife99
lolife99's Avatar
I purchased another repop mirror recently,... hoping the first one I got was a bad one.
Nope.
This one is just as loose.
Really s#cks.
I'm looking for answers also.
Keith
Old 09-28-2011, 10:19 AM   #19
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Mine were once loose also.... no longer an issue, the wife now keeps them safe in a jar.
Dunno where she hides the jar, though......
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-28-2011, 11:05 AM   #20
indianbullet
Location: North Cal and no Sac or Bay area is not NORTH
Thumbs up Re: I've got Loose Balls!.....(rear view mirror)
LockDoc
I did this several years ago on my 72 nova and wifes 68 camaro and works well. I used a automatic center punch, swiveled the mirror beyond its normal area and punched the ball in like 3 spots and it snugged it right up. Its just kinda like putting a bit of knurl on it..
Never argue with an idiot, they will bring you to their level and beat you with experience..
indianbullet is offline   Reply With Quote
Old 09-28-2011, 11:47 AM   #21
Tim Christian
Tim Christian's Avatar
If you will remove the screw from the mirror head they are a little triangle pc. made out of spring steel were the screw would go through the mirror You can replace this only and the the mirror head will tighten up.
Tim Christian is offline   Reply With Quote
Old 09-28-2011, 06:11 PM   #22
lil hoodlum
lil hoodlum's Avatar
I hate to be the redneck, but I too bought an aftermarket mirror, I wedged a couple of tooth picks in mine to get the mirror tighter. I hated the drooping and sagging as well. Mine still shakes some when I'm going 70 down the highway but at least I can see out of it.
Keith
lil hoodlum is offline   Reply With Quote
Old 09-28-2011, 08:19 PM   #23
Tim Christian
Here is the part http://www.classicparts.com/1960-71-...ctinfo/57-411/
Old 09-28-2011, 11:05 PM   #24
-sean-
Originally Posted by Tim Christian View Post
I was wondering what that thing was for! I'm not exactly sure how it goes in but I'm going to order one with my next order and give it a try.
Old 09-30-2011, 06:00 PM   #25
-sean-
Update: I contacted Classic Parts to return my mirror. It was useless and I'm not into fixing new parts. Anyway, they were great to deal with. They shipped me another mirror that they pulled off the shelf and tested before shipping... while I was on the phone with them. They are also sending a return label for the old one (and the new one too if there is an issue).
Great customer service and hopefully it works out, I did purchase the mirror because I need one and they look very nice.
