Old 09-16-2009, 01:55 AM   #1
mongoose
mongoose's Avatar
any other fat guys...
have interference with the wheel?
i've got buckets in it now... with a stock wheel.. i'm wanting to put on a smaller 13'' grant i have, but the adapter makes it stick out another 2.5 inches..
I don't have a stock bench to compare but i seriously doubt it'll get me any more room, and my brother even says it's rather tight... and he's pretty normal.
Anyone wanna share what they've done? if there is anyone.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-16-2009, 02:32 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: any other fat guys...
I raised my seat 1.5 inches. The steering wheel is pulled way. I needed the 1.5 inches to fit the 12" thumpers behind the seat. A benefit was that the steering wheel was moved slightly away too.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 09-16-2009, 02:40 AM   #3
mongoose
mongoose's Avatar
how did you pull it away?
I was looking at physically pushing the column down.. but haven't decided if that's the way to go.
Old 09-16-2009, 06:32 AM   #4
merca
merca's Avatar
i am using a wheel out of a late 80"s cavalier. that gained some room.the next thing may or maynot be safe.i removed the column and fabricated another bracket to weld to the one that holds the column to the dash with about 2.5" differance in lenght on the hole span. then remove the steering shaft from the box and column and compress it about 2.5" inches.the only thing i lost was the switch for the reverse lights was now where the column clamps to the firewall, so i use a toggle switch for them now. you dont lose all the compresion of the steering shaft so some people have told me it is safe , others say it is too risky. use your own judgement
merca is offline   Reply With Quote
Old 09-16-2009, 07:16 AM   #5
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
I went to and early camero/vega steering wheel that is about 14" in diameter. I have measured other factory wheels, like a SS monte wheel from the 80's and it is about 15", the smaller diameter wheel does give you extra room. The other option is to go to a tilt wheel, that helps to.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 09-16-2009, 08:42 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm not too big to fit, but I am a full figured guy. If you don't have a tilt column get one. That will make a difference.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-16-2009, 12:17 PM   #7
Mr.Scary
Project Optimus Prime
Mr.Scary's Avatar
if you dont already have it then tilt sterring is tha way 2 go 4 sure
84 SWB work in progress
89 burb 1500 (parts pig) LOL
08 ford focus (I know, I know) Wifes car
"I said it b4 and i'll say it agian wiring is my worst enemy":devil:
Mr.Scary is offline   Reply With Quote
Old 09-16-2009, 01:17 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
I took my steering column and moved it downward towards the firewall an inch. That meant that I had to change the mounting holes in the steering shaft, but I gained space for the driver. I also use an aluminum steering wheel with the appropriate adapter for mounting.
Frank
Old 09-16-2009, 01:52 PM   #9
SBTork
Garage wrench
SBTork's Avatar
it will for sure!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 09-16-2009, 03:13 PM   #10
Str8Ugly
I'm a rather large guy and my dually has k5 buckets and I have no problem with the wheel
Str8Ugly is offline   Reply With Quote
Old 09-16-2009, 07:21 PM   #11
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
6' 1" and 285 lbs of pure Love Machine and I agree with the above,. Tilt Wheel is the way to go.No silly adapters and if your looking to keep the stock look its a win win
powerdriver 1958 is offline   Reply With Quote
Old 09-16-2009, 08:37 PM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
The tilt column is the way to go for more than just a tight fitting tummy.
The reason I changed mine was because of the angle. With the slightly smaller billet wheel I installed the wheel blocked my view of the gauges, and was just at the wrong angle to be comfortable.
By adding the tilt I could adjust to a more comfortable driving angle and be able to see my gauges too.
Besides, I wanted my truck to have all the factory options I could put in it.
Articles-
"Refining Sierra"
Old 09-16-2009, 09:42 PM   #13
boatpuller
boatpuller's Avatar
go with the tilt.......i'm thinking about one for my computer desk.(just kiddin) i couldn't help it.it's to serious in here sometimes
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 09-16-2009, 11:16 PM   #14
Rollinsqrbdy
Rollinsqrbdy's Avatar
My eyes they burn. Why?
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 09-16-2009, 11:21 PM   #15
mongoose
mongoose's Avatar
I dont know what's worse... on a computer all day that you need a reaching thing.. or that your so fat that you can't rub one out while sitting on the comp all day
Old 09-16-2009, 11:24 PM   #16
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
You are the Why would you do that to us? WHY?!?!
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 09-16-2009, 11:30 PM   #17
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Wow Boat... looks like you LOST a few pounds while you were in Vegas!
CLASSIC87' is offline   Reply With Quote
Old 09-17-2009, 07:33 AM   #18
boatpuller
boatpuller's Avatar
yeah thanks anthony.....had to get in "thong shape" for the vegas pool scene.the speedo look is out now in vegas.so,you gotta do the thong.
Old 09-17-2009, 08:38 AM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
Ya know, I never thought of taking it all off. Heres what I do when I need to cool off.
Articles-
"Refining Sierra"
Old 09-17-2009, 08:50 AM   #20
JohnC
JohnC's Avatar
you guys are nuts!
JohnC is offline   Reply With Quote
Old 09-17-2009, 09:07 PM   #21
spr85gmc
spr85gmc's Avatar
you just described me lol....
spr85gmc is offline   Reply With Quote
