Old 09-23-2009, 03:59 PM   #1
trugertha
which head bolts go thru the water jackets
well i put the head on now i forgot which bolts need silicone..anyone know off the top of their head?? 77 454
thanx
trugertha is offline   Reply With Quote
Old 09-23-2009, 04:20 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: which head bolts go thru the water jackets
The boxwrench site I sent the link for has all this info. Dont use silicone, use a head bolt sealer, AKA anaerobic sealer, they sell it at all auto parts places.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-23-2009, 04:21 PM   #3
trugertha
thanx agian
Old 09-23-2009, 07:42 PM   #4
dammitmitchell
the pollock
dammitmitchell's Avatar
not a single head bolt takes silicone..
use the ANAEROBIC sealers...
it seals due to a lack of oxygen and is less likely to fail under those conditions..
it is thinner so it has a higher chance to adhere to the threads and grooves...
just my two cents
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 09-23-2009, 07:49 PM   #5
James McClure
One shot, one kill.
NO anarobic sealer either, it will lock the threads. Go to your local GM store and get thier teflon head bolt sealer. ALL the bolts get the sealer because it affects torque. Used it for years and still do. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 09-23-2009, 09:08 PM   #6
cLaWz
Ok now I am confused. I was told to use Permatex #2 on all the head bolts but the concensus seems to be otherwise?
cLaWz is offline   Reply With Quote
Old 09-23-2009, 09:11 PM   #7
mongoose
mongoose's Avatar
use the permatex stuff in the white tube thing... should have a flat nozzel on it.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-23-2009, 09:42 PM   #8
asphaltburner
asphaltburner's Avatar
Yo! I've used Permatex thread sealant on ALL the head bolts in each of the 350 V8s I've built without any failures or problems. Comes in normal sealer (blue print, white tube), or high temp. (red print, white tube), just as mongoose has described. I bought mine at NAPA.
The Permatex remains pliable and will not lock the threads,...it also lubes the threads to allow for proper head bolt torque.
It is recommended by Permatex to seal head bolts.
I use it on ALL the head bolts for the simple reason that it's intended for that use, lubes to provide proper torque, and you don't have to guess which bolts go through to water jackets.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 09-23-2009, 09:58 PM   #9
dammitmitchell
the pollock
"permatex anaerobic sealer"
bam! reccomemded by the dealer **** and my drag buddies... so i dont argue i just do and i have not had any problems...
but we all have different opinions.. what does the BOOK say.. =-)
Army vet 02-08
Old 09-23-2009, 10:56 PM   #10
STOCKISH
STOCKISH's Avatar
Anaerobic sealer is not and will not lock up the threads. Ypu can use it on all threads that need a sealer.
--Josh
Old 09-24-2009, 03:54 PM   #11
trugertha
well when i took it apart it had red silicone on it *same stuff you'd use on your valve cover gasket* so i just went with some permatex in the white tube, as thats what my parts guy told me to use. but anyways thanx for the info everyone very helpful.
Old 05-21-2013, 11:10 PM   #12
GuyO
GuyO's Avatar
Yeah the white I temp Permatex thread sealer in a tube is what you want. Just did this today, I used the white tube high temp Permatex that has the flat nozzle. Also, cleaned all the threads up. Then I thought about it, which isn't always a productive process and decided that I should use both: the Permatex red high temp gasket maker and the white thread sealer because I have a half tube of the red already. I put the white thread sealer on the "threads" and ran a small bead of red on the bolt shaft. Anyway I torqued them down in the proper sequence and made three passes to be sure to prevent bolt cross talk. Then I adjusted my lifters with the plugs out (which makes it easier to turn by hand). What a long day and my back hurts from leaning over the radiator support for hours!
GuyO is offline   Reply With Quote
Old 05-22-2013, 12:19 AM   #13
meatwagon83
meatwagon83's Avatar
all of them go into the water jacket! i used the copper permatex on mine
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
