![]() Join Date: Jul 2007
New Hedman Headers - Leaking
Finally got the engine & tranny (5 speed) in my '80 EL C ..... this week installed a brand new set of HEDMAN HEADERS (yes they fit) and a "X-Pipe" 2 1/2 exhaust system.
Now that the car is quiet enough to hear what is going on I can hear/see there is a leak between the left side header & head. For the install new gaskets were used along with new headers bolts and all bolts torqued down. Has anyone else had trouble with HEDMAN HEADERS like this???? Any suggestions for a "fix" or will I have to replace the header???
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? Last edited by PA-IndianRider; 09-27-2009 at 06:37 AM. |
Re: New Hedman Headers - Leaking
Remove the header, use a level/flat surface and ensure the mounting flange is straight. It not, pound it flat or weld to build it up. or just use more gasket in that area.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
F.A.S.T. president
![]() Join Date: Sep 2003
Try it again with a new gasket and if that dont work
return the headers, they are brand new and I'm sure you spent enough on them not to have to fiddle with it.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
You can toss the gaskets and use the high temp rtv sealer.
Registered Truck Offender
It really does work. I haven't used a header gasket on the Nova in years,, just the orange Permetex hitemp. BUT, those are Lemons headers with a nice thick flat flange and Stal bolt pattern, track only car. I've never tired it on a set of street headers. How does it hold up on the street and or a daily driver Alex?
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#6 | |
So I "assume" the Permetex would be used "without" the gasket???
John aka "Milner" PA-IndianRider - Pittsburgh, PA 70 Chevy C10 Stepside "Gasser/Altered Drag Race Hot Rod" Where were You in '62 ? |
are you using the header gaskets that came with the headers? if so i would change them out to a thicker set of percys or felpros.
I have the same problem with a set of Hedman's on my 454 in the '72. These are their $89 street headers and I have to run 2 gaskets on each side to make it seal. The tube of the primary tube sticks out past the flange a bit and causes them to leak like a *****..........
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive Interior 1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories My momma took me off the bottle years ago..... |
Did the headers leak right away or after a couple of heat cycles? THe gasket will set and the bolts will loosen up. If there was a couple of heat cycles on the motor you may want to check the bolts again. Typically takes 2 or 3 re-torques to get them to stay tight.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= ![]() Douchebag Racing: Runs Fine all the Time |
#10 | |
Will work on it tomorrow....
#11 | |
I have had three sets of hedman headers on my truck and never had an issue. They were the cheaper ones to.
If all else fails cut the flanges on either side of the two center primarys. I have seen this done on small blocks. I assume it lets them flex a little.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
as stated earlier the crap paper gaskets that come with headers will leak. get a set of fel pro header gaskets and you wont have any more issues
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#15 | |
I also retorqued them after a few heat cylces and I have a good flat head surface that they bolt to.
