I Love Rusty Chevys
Installing new speakers in 97 Chevy
I bought some component speakers for my blazer that I never installed because they just looked funny. I want to install them in my 97 ext cab.
The 6 1/2's fit just fine but the factory tweeter mounts will not work with the aftermarket tweeter. The aftermarket ones have a mounting bracket that I can screw into the door panel. But I would rather find a way to mount them in the stock location. I also need to find a place to mount the crossover box(what ever it is called) Has anyone installed something similar or have any ideas on what I can do to make it look like a pro installed it instead of an idiot ......ie ME. I installed one of the woofers and it sounds terrible with the stock cd player. Thankfully I have an old cd player that I will be installing once I receive my install kit.
1969 K5 Blazer 1997 1500 Silverado Ext Cab Z71 2010 1500 Silverado Ext Cab Z71 Last edited by Otsa580; 09-30-2009 at 05:15 PM. |
I Love Rusty Chevys
Re: Installing new speakers in 97 Chevy
Some more pics
I've thought about installed the crossover box on the kick panal and running the speaker wires through the door. I could try and mount it in the map pocket on the door but that might be a pain.
1969 K5 Blazer 1997 1500 Silverado Ext Cab Z71 2010 1500 Silverado Ext Cab Z71 |
>130dB Moderator
Find a place inside the door to zip tie that crossover and make sure it doesn't get wet. The armrest is usually a good place for that.
As for the factory tweter mount, I don't think you can use it seeing as the TMA tweeter is a bit bigger. You MIGHT be able to enlarge the hole in the mounting bracket on the stock part and adapt it to the TMA tweeter. The other option is to pt the tweters in the dash.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
little cutting and some abs plastic will mount that tweeter in there
| Bookmarks |
| Thread Tools | |
| Display Modes | |
