Old 10-21-2009, 10:52 PM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
LS1 year questions
Hey guys, I have a line on a wrecked 99 van (sposed to be 3/4 or 1 ton)
And I was wondering... being a 99 would it have a LT1 or a LS1 ??? Either way cast iron block & heads correct ???
Also if it is a 3/4 or 1 ton, wouldnt it have a 4L80E ???
Just really would like to have a LS1, but either way Ima try to get the parts
Also, did GM change the bell housing pattern when they went to LS1 ???
Thanks, Matt
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-22-2009, 01:06 AM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: LS1 year questions
Also what would the stock HP rating be on the engine ???
Sinister
Killer
Old 10-22-2009, 02:22 AM   #3
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
A 1999 G-van would actually have the trusty ole L31 5.7L 350 or possibly a L29 7.4L 454. The LS series (4.8, 5.3 and 6.0L) engines didn’t appear in the G-vans until 2003. If the van is indeed a 2500 or 3500 it would have a 4L80E.
And yes, LS engines still use the same ole Chevrolet Bellhousing that has been around for over 50 years.
DirtyLarry is offline   Reply With Quote
Old 10-22-2009, 07:57 AM   #4
fiddy9apache
fiddy9apache's Avatar
the trans will bolt up on both the LS and non LS engines but you have to get a custom converter if you wanna run a other gm trans like a 700r4, th350-400. but no need to worry about that, since its a non LS engine the 4l80e will bolt up to what ever you want.
fiddy9apache is offline   Reply With Quote
Old 10-22-2009, 08:10 AM   #5
fiddy9apache
at the rear wheels about 195hp
Old 10-22-2009, 03:49 PM   #6
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks guys
Sinister
Killer
Old 10-22-2009, 05:19 PM   #7
clinebarger
You dont need a custom converter. advance adapters has a kit that has a spacer and flexplate. 6.0s with the 4L80E came factory with a crank spacer
(99 6.0s had a special crank with the spacer made into the crank)
clinebarger is offline   Reply With Quote
Old 10-22-2009, 05:29 PM   #8
clinebarger
Where did this number come from? you dont know what engine it has.
you say "at the rear wheels" thats a hard thing to guess. 4L80Es sap alot of power. So does a 14bolt diff. GM doesnt publish rear wheel horsepower
Old 10-22-2009, 07:18 PM   #9
fiddy9apache
ive seen it with my own eyes, L31 put down 195hp all it had was exhaust. it was a 2wd tahoe with a 4l60. your correct i dont know what engine it has but since its in a van its most likely goin to be a L31.
i would just prefure not to use adaptors, im sure he isnt goin to use the stock converter anyways. might as well get the correct one.
Old 10-27-2009, 09:44 AM   #10
Shon
I have the adaptors to run a Th400/350 on the LSx blocks if you need them. We had a ton made for the local jeeps we do the swaps in.
and we normally just take the LSx flexplate and redrill the TC mounting holes.
TCI makes a kit that has the flexplate and spacer, if you want that kit let me know.
Just look at the current FP and see if it has the crank spacer behind it, the 6.0s sometimes do and if that is the case you do not need anything, might have to redill the FP but otherwise you are good to go.
as for the bellhousing, the LSx has 8 bolts, to put the older GM trans to the newer motor just use 6 bolts, a 7th might line up but we just use the 6bolts.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
