Old 10-27-2009, 06:15 PM   #1
63whoopie
Inline 6 manifold/carb warmers?
Ok, so I am planning on adding some sort of aftermarket intake to my I6 250 in my 1963 C10. I've bid on a few 2x2 intakes, and, most recently, a single 4-bbl intake in Ebay. My question is:
I keep reading that you need to heat the fuel mixture for regular driving my tapping a hole in the manifold, etc. I heard someone in my hometown recently say that you could just use a heated spacer (?) so as not to have to tap the manifold, and add the space of a carb spacer for the fuel density. Does anyone do this, recommended for or against, or have an opinion on whether to tap the manifold or look for a spacer than is set up to be heated? Clifford apparently might have made a heated spacer, but doesn't anymore, I checked.
Thanks in advance.
63whoopie is offline   Reply With Quote
Old 10-27-2009, 06:48 PM   #2
slepysal
slepysal's Avatar
Re: Inline 6 manifold/carb warmers?
My 60 it has an old Clifford, with no heat provision, but hear in San Jose it isnt that big of a problem.
Clifford now makes there manifold with the provision to use water to heat the intake, Offy's are made to "bolt" to your stock exhuast or to use an an addapter available thru Tom Langdon I m sure some one will post the website , if not Ill find it for you
Good luck and post some pics
Hey Chief I got the Offy for you.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-27-2009, 08:42 PM   #3
ol Curt
Junior Member
ol Curt's Avatar
www.stoveboltengineco.com/
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 10-27-2009, 08:51 PM   #4
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
How'd you know I'd be reading this !!
Got a pic ?? PM me man !!!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 10-27-2009, 10:28 PM   #5
63whoopie
ok, found one of the carb spacer/ heater plates i had heard of. Apparently, they're out of production, and have been for some time. I am going to guess that this will be just as good as tapping the manifold itself?
Old 10-27-2009, 11:53 PM   #6
slepysal
slepysal's Avatar
Will take some tomorow
what type of manifold do you have ?
try this as olcurt sugested
http://www.stoveboltengineco.com/aca...?productid=144
Old 10-28-2009, 07:53 AM   #7
ol Curt
Junior Member
ol Curt's Avatar
I used an Offenhauser intake on with dual Rochester carbs and the heater plate from Langdon. It worked fine on mine.
1963, c10, carb, inline, six cylinder
