Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-27-2010, 04:47 PM   #1
BIG KRIS
BIG KRIS's Avatar
Air suspension on the street and strip
Are there any c10s out there running air bags that's seeing some street and strip duty? I got a call today from the speed shop I deal with abot a couple of big blocks and I'm highly interested,but I also have plans on doing a dropmember and 4link rear with 20s or 22s tucked in the rear. I guess I wanna now will it be a waste with air if I still wanna have some track day fun?
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 01-28-2010, 10:31 AM   #2
BIG KRIS
BIG KRIS's Avatar
Re: Air suspension on the street and strip
Let's not all comment at once. Lol
Dropmember
Old 01-28-2010, 10:42 AM   #3
Wild83C10
Wild83C10's Avatar
I don't see why you would have any problems running bags. The bags will allow you to make more adjustments then regular springs (ride height, spring rate?). As long as you have a good shock you should be fine.
I don't run air bags and I am using coilovers for my C4 DM. I also don't know of any vehicles that drag race and use bags. Not sure why they don't, could be because of space and weight though.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 01-28-2010, 11:14 AM   #4
BIG KRIS
BIG KRIS's Avatar
You running coil overs in the rear or all around? I'm thinking about a coil over rear but the only way I've seen to run coil overs in the front is the fatman fabrication ifs front end
Dropmember
Old 01-28-2010, 11:29 AM   #5
Wild83C10
Wild83C10's Avatar
I am running coilovers at all 4 corners. I have the C4 DM so it's setup for coilovers or airpsring over shocks which is equivalent to the coilover. I have dbl adj. in the front and I will probably run single adj. in the rear.
turbo=
Old 01-28-2010, 12:56 PM   #6
BIG KRIS
BIG KRIS's Avatar
Wildcat do you have any pics of your truck and set up?
Dropmember
Old 01-28-2010, 01:53 PM   #7
71Dragtruck
71Dragtruck's Avatar
Can't run bags at the strip, NHRA rules don't allow it, because of what happens if you blow a line or bag and they deflate going down the track.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 01-28-2010, 04:53 PM   #8
BIG KRIS
BIG KRIS's Avatar
So static or coil overs may be best thing for a street rod that rolls to a test and tune from time to time.
Dropmember
Old 01-29-2010, 07:19 AM   #9
Wild83C10
Wild83C10's Avatar
Wildcat? is that me? I will have pictures soon.
turbo=
Old 01-29-2010, 09:13 AM   #10
BIG KRIS
BIG KRIS's Avatar
Wild83c10 sorry about that man this suspension stuff got me tweaking. Lol
Dropmember
Old 01-29-2010, 08:57 PM   #11
Wild83C10
Wild83C10's Avatar
No sweat, don't worry about. I thought it was funny, just wondering how you got WildCat?
If I get out in the garage this weekend I will get some pictures. It only reached like 23 degrees today.
turbo=
Old 01-29-2010, 09:38 PM   #12
BIG KRIS
BIG KRIS's Avatar
It didn't get that hot tody.
Dropmember
Old 01-29-2010, 09:39 PM   #13
Chevy-Art
Chevy-Art's Avatar
I have seen bagged trucks at the track, and they are running pretty good times.
1990 Chevrolet RCSB●LS1/4L60E
Scrimpin Ain't Easy
I'm not a mechanic, I'm not a tuner. I'm just an enthusiast.​
Chevy-Art is offline   Reply With Quote
Old 01-29-2010, 09:49 PM   #14
BIG KRIS
BIG KRIS's Avatar
I was thinking bring it out on a street chaos night and bait a sucka! Old square body damn near sitting on the ground, and be like give me 2 and the break with this lil ole 468 or a 502! Lol
Dropmember
Old 02-01-2010, 07:43 PM   #15
Wild83C10
Wild83C10's Avatar
Ok here are some pictures of my setup. I just have to come up with some sway bar mounts and the front will be done. The rear is still in process (as you can see). I will be running a 1-5/8 tube on the underside of the top frame flange to mount the coilover upper mount. I am currently building a crossmember for the trailings, but I may buy the CPP crossmember.
turbo=
Old 02-01-2010, 08:02 PM   #16
Alex1
Alex1's Avatar
whoa! what control arms are those?
Alex1 is offline   Reply With Quote
Old 02-01-2010, 08:46 PM   #17
Wild83C10
Wild83C10's Avatar
Those are Corvette C4 CA.
turbo=
Old 02-01-2010, 08:59 PM   #18
BIG KRIS
BIG KRIS's Avatar
Man did you fab it all up yourself? I thought about coilovers my buddy has a chasis shop he wants to do my truck. Does anyone run the ifs kit from fatman fab I was looking into that claims its abolt on deal with 6inches of drop and no clearence problems.
Dropmember
Old 02-01-2010, 09:18 PM   #19
djracer
djracer's Avatar
looking good. Are you just now adding the trailing arms or have you run them before.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-01-2010, 09:42 PM   #20
Wild83C10
Wild83C10's Avatar
Nope its a C4 dropmember. It helps in a lot of ways. Weight transfer, it should handle better and with the dbl adj coilovers I should get better track times.
If you don't care about cutting/welding up the frame too much and not too concerned about weight lose the IFS kits aren't a bad option.
turbo=
Old 02-01-2010, 09:43 PM   #21
Wild83C10
Wild83C10's Avatar
Yup just adding the trailing arms. I bought most of the stuff a few years ago and I'm now working on the install. Been looking forward to it for awhile now.
turbo=
Old 02-01-2010, 10:13 PM   #22
djracer
djracer's Avatar
I have the fatman kit and its bolted on.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
