Old 02-19-2010, 04:19 AM   #1
OARNGESI
OARNGESI's Avatar
Installing a different size rearend
Hi i got a rearend i want to get to work with trailing arms its a different diameter than the regular 3 in does any one make a kit for this has anyone done this
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-19-2010, 07:45 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Installing a different size rearend
The only one I know is ECE's trailing arm mount. I wonder if you could modify them to work?
Keith
Convert to disc brakes.
Old 02-19-2010, 10:31 AM   #3
Mike J
vw guy & now c-10 guy
Mike J's Avatar
you're talking about the weld-on perches, right? I think CPP sells them in different diameters for different rear ends- I could be wrong though- check out their website.
OK, I looked at their website- they do have them-BUT only show them for 3" axle tubes- so maybe contact Jeff and see if they can make you something?
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 02-19-2010, 10:50 AM   #4
OARNGESI
OARNGESI's Avatar
Yeah right now i just wana be able to bolt the rear up
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 02-19-2010, 11:52 AM   #5
Tony@AirRideTech
Junior Member
Dont forget about the panhard bar which the factory rear end has a bung cast onto the houseing.... you can always go to a weld on panhard bar but it has to be in there. If you are going to a different 10 bolt or 12 bolt, we do have a panhard bar bracket that relocates the bar further down to correct its positioning for a lowered ride height. The axle brackets are gravey... you could even get in touch with Mosier for some replacments to weld onto a different rear end.
Tony@AirRideTech is offline   Reply With Quote
Old 02-20-2010, 03:06 AM   #6
OARNGESI
OARNGESI's Avatar
Thanks alot ill check with them
70 SWB STEPSIDE
70 BLAZER
09 challenger
