02-20-2010, 04:43 PM | #51 |
67-72 parts collector,…
Re: Brake dilemma, need advice
That doesn't make sense going thru a factory porportioning valve. Your's looks just like the one ECE sells in their kits.
(like a 73-87 version, with one front port closed off) Also how deep is the pushrod hole in the back of the M/C? Seems like I remember the "manual brakes" having a deep hole and the "power brakes" have just a shallow button to just center the pushrod. (like an inch difference in the two lengths).
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-20-2010 at 04:59 PM. |
02-20-2010, 05:02 PM | #52 | |
The depth of the hole is approx. 1 3/8" deep. If you look in one of the pics you can see the rod poking out of the booster. "It appears".............to be the propper length for this MC ,(I guess). Appearences and measurements are two totally different things though ,I'm probably wrong.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
02-20-2010, 05:32 PM | #53 |
Here's a couple pics from my '71 Big Block parts truck.
This thing is rusty, but mostly unmolested. It has the exact same M/C and booster. Same line sizes and placement also. (3/16" line on the front reservoir and 1/4" line on the rear) If you want,... I can run out and pull the M/C away from the booster while it's still daylight here. I really think it's the M/C and porportioning valve combo,... but I hate throwing money at problems. I'm running out of ideas.
02-20-2010, 05:34 PM | #54 |
Your porportioning valve is a little different.
02-20-2010, 06:16 PM | #55 |
I think what you have is correct.
I took mine apart, (because I just had to know), and it looks like the booster rod length is about the same. 4.031" total when I pulled it out of the booster, and approximately 1" past the rubber boot of booster. I assume the small o-ring is still on this rod? The plunger depth of the master cylinder is approximately 1.625", so that blows my theory. Yours pedal linkage does have the same pivot assembly prior to connecting to the booster. I know my M/C (that I got for my '69 from PerformanceOnLine.com), said to make sure that the depth of the plunger was the same. I can't find my paperwork, so I must have thrown it away. Sorry,... I'm not much help.
02-20-2010, 06:49 PM | #56 |
These are right out of the POL (Performance OnLine) catelog.
My booster had Delco/Moraine stamped on the front. Look at the different applications of the Moraine booster. (up to '78) Also notice in the picture of the booster,... they show two different length M/C pushrods. Hope this helps and doesn't add to the confusion. (notice the C20 M/C has a 1-1/4" bore)
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 02-20-2010 at 06:52 PM. |
02-20-2010, 07:52 PM | #57 |
THANKS for the info lolife, it helps.
The more I keep digging and the more people I talk to the more the MC and prop. valve keep coming up. I agree it's gotta be something with those two things. I ordered some stainless steel lines and I think I'm gonna just get a new MC and prop valve when they come in. If the problem still persists after that I have no idea what I'll do. Like I said before the brakes work they just don't work as good as they should and they just won't lock up no matter how hard I push the pedal.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 Last edited by Painter D; 02-20-2010 at 07:53 PM. |
02-21-2010, 01:22 AM | #58 |
I have been watching this problem and am thinking that the pedal arm has 2 holes in it. 1 for power and another for manual. That could make quite a differance as far as the leverage goes.
02-21-2010, 12:19 PM | #59 | |
Size Matters
Your Chit looks better than my Chit.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
02-21-2010, 12:42 PM | #60 |
I haven't tried swapping the lines yet, I'm gonna wait until the stainless steel lines show up and try that first.
03-01-2010, 03:53 PM | #61 |
I saw you got your lines. I'm subscribing to this thread to see how it all turns out. We're about to go through putting ours back together too and I'm worried about a similar outcome. Good luck!!!
Eric 1967 C10 SWB 383 Stroker/TH400 Brother's One Piece Power Windows Shaved Doors, Markers, and Bumpers 4/6 Early Classic Drop Rear Fuel Tank (49-52 Chevy Car Tank) Surf Blue Paint Bella Vista, AR (Arkansas for those that get the 'A' states mixed up) My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869 Last edited by es67chevy; 03-01-2010 at 03:53 PM. |
03-01-2010, 08:41 PM | #62 | |
After that weekend I'll probably have time.
04-07-2010, 10:33 PM | #63 |
Problem solved.
After I finish with my motor swap I'm ordering a whole new big brake system. When I say "whole system" I mean a whole system. Not sure which one yet ,I'll keep you guys posted.
04-07-2010, 11:17 PM | #64 |
BMW & ASE Master Certified
ha, i just read a post about a guy having the same question... they were talking about the smaller brake line... quoteing from another forum
"Think of it as the effect acros the length of the tubing. With 3/16" tubing, 1/2" of pistn stroke is 1/2" of fluid movement into the atrium of the calipers (I am leaving the calipers themselves out of the equation as that is particular to the volume needed for any specific caliper). Now, use a 25% larger i.d. tubing from the dist block to the rear and going from 3/16 line out of the MC to the dist block (without doing exact math) 1/2" of piston stroke will be about 3/8" into the calipers. but the fronts will not experience this drop as they use the smaller i.d. lines. This effectively increases the front bias already built in to the MC" plus I dont think your supposed to run a proportioning valve + an aditional prop valve... is that what your running or a stock gutted one plus an adjustable... i also read on the site that thats no bueno... clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
