Brake dilemma, need advice
I'm sick of my brakes! No matter what I do my brakes just don't stop the truck fast enough. I just put dual piston Wilwood D52 calipers, drilled and slotted 12" rotors, and steel braided hoses on the front and no matter what speed I'm at they still won't lock up no matter how hard I push the pedal.
I have the right MC , I have the rod adjusted correctly, I have the right proportioning valve, I have a good booster, I have a vacuum reserve canister, and I have bled them too many times to count. What am I missing? The only thing I can think is my MC isn't putting out "enough" pressure. Do I just need to spend the money and get a hydroboost setup? Normally I wouldn't worry too much about this but if some kid runs out in front of me I honestly don't think I could stop fast enough.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Brake dilemma, need advice
Do you think and adjustable porpotioning valve in the rear line would help you dial it in?
Which bore master cylinder? 1" or 1-1/8" bore? Also disc/drum or 4 wheel disc? |
What is the vacuum level @ the vac can?
I have an adjustable prop. valve on the rear line, I'm not sure on the bore size, and it's a disc/drum setup.
SCOTI ,I'm not sure what the vacuum level is at, I don't have a guage.
You know someone that does. Let's try & get together this weekend maybe & see what it is??
I'll try, but I have another problem that developed on the test drive for the brakes. My elec. fan decided to come loose and put a small hole in my radiator so now I have to get that fixed.
I swear this truck hates me.
Active Member
Basically there are 2 ways to improve the brakes.
1- Use a bigger booster, or use a Hydaboost. The Hydraboost are the most powerful booster you can get. 2- Use a larger rotor. The CPP 13” kit or the Willwood 14” kit will improve the brake performance. FYI: The D52 caliper has almost the same piston area than the OE caliper. This web address shows the output of different boosters. http://www.classicperform.com/PDFs/B...ssureChart.pdf Danny Nix CPP |
Just to throw my 2 cents in, I was working on my buddy's Chevelle recently and he had a booster that was less than a year old that we had come to find out was blown. Also the check valve was blown. If you ever experienced any backfire while tuning your truck that could have blown out your booster. My buddy had the canister and new brake system on his car too. I took the booster out and she was toasted. I'm sure you've checked your drums already too, but just in case, make sure those axle seals aren't leaking onto the shoes.
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
I find it odd that you can't get enough pressure to lock up your brakes, especially with the upgrades you have made. Has the problem always been there? Is that the reason you upgraded the brakes to begin with? If the problem was present before the upgrades, what components have NOT been replaced yet?
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#10 | |
To the best of my knowledge the rear brakes work perfectly it's only the front ones that seem to just not get enough pressure. The lines aren't clogged ,I get plenty of fluid when I bleed them just not enough pressure I guess. Could I possibly need a new MC ,maybe one that has more pressure than stock. I do know for sure it's not the calipers, rotors, hoses, or pads they only have about 4 miles on them and they are brand spankin new. ![]() ![]()
Have you broken in the pads? some times it takes quite a while for them to seat in. Four miles doesn't sound like enough. Maybe somebody else has some info on breaking pads in. good luck
#12 | |
#13 |
Do you feel it when your booster gets vacuum with your foot on the brake and starting the truck? I thing something is up with your booster. Also really double check the brake push rod adjustment. You have some component not working, the stock disc drum stuff should lock up no problem! You don't need a more powerful mastercylinder or booster.
#14 | |||
#15 |
Look at Wilwoods website.
There a FAQ section and a troubleshooting section. Seems like master cylinder bore size is an important part of brake pressure produced by the master cylinder. |
#16 | |
I've yet to have an issue w/brakes when using the correct GM parts (calipers, rotors, master, & booster). If they are (were) sourced correctly, I think the vacuum issue needs to be verified. Vacuum is what these brake systems require to 'boost' the pedal pressure. A vacuum system w/o vacuum will not hit it's intended pressure range. Sure the rears will lock up but that can be a result of limited weight & the natural weight transfer that occurs during harder braking.
#17 |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-11-2010 at 08:55 PM. |
#18 |
THANKS for all the help guys.
Who the hell knows what's going on or exactly which MC or booster I have, like I said I got them at O'reilly's. I guess I'll look into the bore size of the MC and go from there. If all else fails I'll just replace both the booster and MC with some good aftermarket parts and see if that fixes it. Right now I have other issues with the truck when I was on the test run for the new brakes not only did I put a small hole in my radiator I think I knocked a lobe or two ,or three off the cam as well. I was "wanting" to do an engine swap anyway ,but that "want" may become a reality pretty quick.
#19 |
Sure sorry to hear about your other problems. I am doing the same kind of build as you -- but plan on driving around in primer for a while to get all the little issues and bugs worked out before i paint. I painted and did the interior on a truck almost 20 years ago -- drove it to work to show it off and broke down on the way to there!! Anyhow -- looked at your thread and will have to say your build is AWESOME..love the blue!
REAL interested in hearing what your brake problem turns out to be -- mine sounds EXACTLY the same.... |
#20 | |
#21 |
Size Matters
Try this method of bleeding:
1. Open at least one if not both front bleeders and put a vacuume hose from the bleeder into a plastic drink bottle (to keep from making a mess). 2. While the front/s are open, bleed the RR and then the LR. Keep checking the master cylinder to make sure you don't run dry. 3. If you have the LF open, close it. 4. Bleed the RF. 5. Bleed the LF. If your pedal is not rock hard after trying this, try it again at least once. If still not rock hard, replace the master cylinder. FYI, even if your booster is bad, if you stand on the brakes hard enough, you should be able to lock the brakes.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() |
#22 |
Moderator
![]() Join Date: Jul 2006
I've had a bad "new" booster from O'Reilly before. I would start there, sounds like all the other variables are covered.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#23 | |
At idle in gear it's pulling 10in. hg vacuum At idle in park it's pulling 13in. hg vacuum When I rev it up it goes up to about 20in. hg vacuum I don't know if those readings are good ,bad, or normal but that's what they are. While I had it running I pushed the brake pedal with the booster hooked up and without it hooked up ,and I can definately tell it's working when it's hooked up. I just don't know if it's working up to the level it needs to be at. What do you guys think?
#24 | |
What cam do you have? 10" of vacuum is not enough to run your brakes properly.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#25 | |
Not sure if it matters or not but I used to have a more mild engine setup with a less aggressive cam in it, and the brakes acted the same way then too.
